Old 06-13-2010, 12:40 PM   #1
idaho66stepside
idaho66stepside's Avatar
Question Engine miss
Hey gang, I'm wondering what to look for when my 350 in missing some. If the timing is right and the valve adjust is good, what else should I look into. Thanks
idaho66stepside is offline   Reply With Quote
Old 06-13-2010, 01:05 PM   #2
neto
neto's Avatar
Re: Engine miss
Spark plugs or spark plug wiring. Make sure the wires aren't touching the exhaust manifold.
neto is offline   Reply With Quote
Old 06-13-2010, 09:11 PM   #3
erock805
erock805's Avatar
Re: Engine miss
absolutely...with the engine running pull each plug wire off one at a time and listen for a change in the engine idle. if it doesnt change..thats your your issue!
"Do what you want to the girl, but leave me alone!"
erock805 is offline   Reply With Quote
Old 06-13-2010, 10:10 PM   #4
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Engine miss
Don't use your hand to pull the wire off. Use spark Plug wire pliers. You could also pull the cap and make sure there is not a crack in it.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
