Old 06-13-2010, 02:33 PM   #1
jwalk
What was I thinking?
jwalk's Avatar
Big block oil pan question…
I think there was two different oil pans for a big block. A five quart pan for most cars and a seven or eight quart pan for trucks. My question is, is there a way to tell which one I have in my truck? To me it looks small like a five quart pan, but I'm not positive. Didn't know if the drain plug was in the same spot on both pans, or if a guy could measure the dimensions and tell…
Thanks,
Justin
jwalk is offline   Reply With Quote
Old 06-13-2010, 04:57 PM   #2
CE20934
CE20934's Avatar
Location: Help! I'm in an office park with its own network of freeways!
Re: Big block oil pan question…
I believe the sump area of the seven-quart pan extends farther forward than the five-quart. I know I had to massage my seven-quart pan to clear the crossmember.
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man)
'95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis)
'07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed*
CE20934 is offline   Reply With Quote
Old 06-14-2010, 01:16 PM   #3
jwalk
jwalk's Avatar
Thanks CE20934. Does anybody else know the differences in pans?
Thanks,
Justin
Old 06-15-2010, 04:05 PM   #4
orneryolbiker
orneryolbiker's Avatar
The eight quart pan (Chevy truck) is approx eight inches deep and requires a deeper pick up tube, I use the 1985 gmc 3500 specs for engine parts reference, If the eight quart pan hits the cross member there is a problem in the motor mount area, I have three 1971's all with bbc and eight quart pans with the right motor mounts there is about an inch clearence between the back cross member lip and the front of the curved part of the pan.
orneryolbiker is offline   Reply With Quote
Old 06-15-2010, 04:56 PM   #5
John Pasinski
John Pasinski's Avatar
If I may ask a question. I'm searching for this exact item in the GM Chassis & Body parts catalog. There are a couple of abbreviations I'm unable to figure out. They are: D-D & MHC. Does anyone know what they stand for? I have a 402 & I'm trying find the correct oil pan size & dip stick length. I'm wondering if I'm running my engine crankcase low on oil. I'm putting in 5 qts including filter. Maybe it's possible that it's an 8 quart?
orneryolbiker I'm gonna measure my pan & see if the sump's 8". Do you or anyone else know the depth of a standard oil pan?
A man's thoughts devise his ways; but it's GOD that directs his steps.
John Pasinski is offline   Reply With Quote
Old 06-15-2010, 05:22 PM   #6
orneryolbiker
Ok, I went to the shop with old rusty tape measure, eight quart pan is just shy of 9 inches from lip to bottom, the 402 pan I have is chrome so I'm not sure if it has same as stock demension, it is however, just over 7 inches in depth. None of my pans seem to have a stamped number. I don't know if the 402 truck pan was 5 or 8, there are guys on this forum that would know that info, some of the smartest people I know drive ol chevy trucks
Old 06-15-2010, 07:14 PM   #7
CE20934
CE20934's Avatar
Are your engine stands in the V8 or I6 holes?
Old 06-15-2010, 07:44 PM   #8
orneryolbiker
It's been 20 years since I had a running six in a truck, but If I remember correctly the six motor mount holes are the back ones and the v-8 are the forward ones mine are in the forward holes. all three of my 71's were 307 three speed fleet trucks. I put the factory big block towers and motor mounts
in them. Believe it or not I got all of those mounts and towers directy from GM about 15 years ago.
Old 06-15-2010, 08:30 PM   #9
jwalk
jwalk's Avatar
Thanks guys. I'm pretty sure I've got the five quart (car) pan. I know I have the 67-71 BBC motor mounts in the correct holes.
Old 06-15-2010, 09:41 PM   #10
CE20934
CE20934's Avatar
Huh. My mounts are also in the forward/V8 holes, but that truck pan needed about an inch of massaging to clear the crossmember. However, I'm running the wrong ('73-87) mounts in a frame not designed for a BBC ('67), so that's two strikes right there.
Old 06-15-2010, 11:38 PM   #11
orneryolbiker
I believe if you look at the stock 71 big block tower you will see the difference. The vertical bolt mount hole sits back about an inch from where the 73-87 mount sits, even though they bolt to the frame in the same place. I have been told that there were some late 72 models that used the newer mount also, but that is just what I was told.
Old 06-16-2010, 07:27 AM   #12
CE20934
CE20934's Avatar
The '72-only mount is a hybrid of the two styles: same bolt holes for the frame as the '68-71, looks similar to the '73-87, and uses the clamshell mount like the latter. They pop up on the parts board from time-to-time.
After more research, I might have found another strike against me: I used the bellhousing mounts as my fixed point to locate the engine mounts. Supposedly there were three different locations for that thing too: I6, SB, BB. The SB location is about an inch forward of the BB location, so since my truck was a 327/4spd originally, that puts my 427 an inch farther forward than it should've been.
Meh, it runs well. That's what I care most about.
Old 06-16-2010, 11:36 AM   #13
orneryolbiker
I love my big blocks I have had them from 396 to 540 cubic inches. Lately I have been oogling the ls engines. I bought my wife a ws6 trans-am and I am very impressed with it. maybe on the next truck
