Old 06-13-2010, 03:30 PM   #1
jacko
cab same?
does anyone know if the cab on a c 10 is the same as a k10 cab except for the tranny tunnel hump... i have a good c10... but need to put on my k10
jacko is offline   Reply With Quote
Old 06-13-2010, 06:31 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: cab same?
Yes they are the same. That is similar to what I'm doing for my project accept taking a cab off a 63 C50 to a 64 K10 frame.
LINK to build thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=397681
Old 06-14-2010, 02:26 AM   #3
LILRED66
LILRED66's Avatar
Re: cab same?
The tranny hump cover is specific to the tranny type, not wheter it is a C-cab (2wd) or K-cab (4x4).
LILRED66 is offline   Reply With Quote
Old 06-14-2010, 05:49 AM   #4
apachedaddy
apachedaddy's Avatar
Re: cab same?
I thought there was a diff in the cab mounts also???
66 short wide fleet sbw = Gave to my best friend
66 short wide fleet bbw
apachedaddy is offline   Reply With Quote
Old 06-14-2010, 08:23 AM   #5
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: cab same?
the only other difference is the c or the k in the vin tag, which might cause trouble with insurance or registration...
Old 06-14-2010, 12:26 PM   #6
Jakes-66-K10
Jakes-66-K10's Avatar
Re: cab same?
K20's do have a different rear mount, if I remember correctly. But C10 and K10 use the same cab mounts, doing the exact same swap myself.
Jakes-66-K10 is offline   Reply With Quote
Old 06-14-2010, 12:33 PM   #7
raycow
Re: cab same?
Jonz raises a very important point. In most (maybe all?) states it is illegal to remove the VIN tag or transfer it to another body. Is your K10 licensed/registered for road use? Do you have a title for the C10 that the cab came from?
Ray
raycow is offline   Reply With Quote
Old 06-15-2010, 12:54 AM   #8
Captainfab
60-66 Nut
Re: cab same?
The C20-60's and K20 & 30's all use the vulcanized rear cab mount. However the location of the mounting hole in the cab remains the same within the '60-'66 years.
