![]() Join Date: Oct 2007
Door Panel Questions
I am wanting to paint my door panels a semi-gloss black .
I washed the panels with a SOS pad and now would appreciate some info on what is the best way to make sure the paint sticks and does not peel off after I paint them. Pictures show that I have went through the black that is on them with the SOS pads in some places and other places I have not. I plan on shining up the chrome and putting it back on the panels with out the metal woodgrain insert .. The places that I have gone through the paint is showing what the plastic looks like from the rear side of the panels .. My questions are these ..Do I have to take off all the black on the panels ? Or do I only need to get off the paint that comes off by scrubbing them like that is shown in my pictures below .. Do I need a primer first before I paint the simi-gloss black ? Was hoping that some others have been there done this and know whats best ..thanks GP Larry ![]() ![]() ![]() |
SWB 4x4 Collector
![]() Join Date: Jun 2001
Re: Door Panel Questions
Get some lacquer thinner and some rags..... start wiping with elbow grease. It will take some time but shouldn't damage the panel as I have used the same method in the past. Get it good and clean, then wipe down with a sos pad gently mixed with some soap and water. Wash off, and let air dry. Then finish up with some Bulldog adhesion promoter (about 2 mist coats, 5 min. apart) Wait another 5 min. and use some SEM interior ColorCoat of your desired color, and boom. You have a nice set of panels. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
#3 | |
