Old 06-14-2010, 10:57 AM   #1
Fat Mike
Fat Mike's Avatar
Larger Brakes for S-10 Conversion
Is there any other model of larger brakes that are a straight bolt in for the s-10 conversion. Looking for low buck and need brakes, caliper, and rotors possibly off a used vehicle. I was told that you can get a wider stance by using the larger brakes. Need to make up 1.5"- 2.5". I did some research on extended a-arms but was told that it won't widen my stance it will just change the camber? Need help and pictures if possible.
Fat Mike is offline   Reply With Quote
