Old 06-14-2010, 01:58 PM   #1
EZTHERE
oil drip stick problem
well I bought this 72 jimmy, now im finding an oil leak from the dip stick. as it turns out some one broke the tube in the block. Its broke right where the tube butts up against the out side of the block. to fix that they fast weld 10 the other half of the tube on to the part that snapped off. But it leaks. Im i screwed? or can I some how pull the broken portion of the tube out of the block with out dropping the pan.
Also is there a skinny'er tube that I can just fit inside the broken one...
im pissed.
EZTHERE is offline   Reply With Quote
Old 06-14-2010, 02:10 PM   #2
EZTHERE
Re: oil drip stick problem
ok ive read where some one made a tool to remove the busted part. Is this availible at the local parts store?
Old 06-14-2010, 02:39 PM   #3
elks
I had a similar issue once. The good news it that the tube should only be pressed in and require a little effort to remove.
In my situation I dug around and found screw that would thread itself into the sleeve. I then pulled it out. I would think that a tap set would have what u need as well. Regardless fix it right, pull the old one and get a new one. Do not use a sleeve in a sleeve.
Hope this helps.
Also welcome to the world of old vehicles. My guess is that overtime you will find a lot of similar "what the hells".
Confidence is the feeling we have before we fully comprehend the situation
elks is offline   Reply With Quote
Old 06-15-2010, 02:37 PM   #4
Tynee
I miss this truck.
Tynee's Avatar
If you sleeve it, the dipstick may not fit through the inner sleeve.
'07 GMC Acadia SLT. Sweet ride.
'08 Crew Cab Z-71 short bed. Really like this truck A LOT.
Tynee is offline   Reply With Quote
