Old 06-14-2010, 02:05 PM   #1
nlped
nlped's Avatar
Front Brake hose removal ???
Okay, I have done this several times before on other trucks, but with this '76 Blazer I am having some issues getting the front brake hoses off. I cannot get my hands on the actual hardline fitting that screws into the factory brake hose. With the fuel line & trans cooler lines on the passenger side and the P/S hoses on the driver's side, I can't get my hands in there well enough to get a 3/8" line wrench on there and pull or push. Is there another way to access this joining of the lines? Could I pull that big cheesy nut off of the backside of the frame, that appears to be holding the rubber line in the frame, and pull the rubber line and the hard line through the frame and get them loose that way? Just curious to know if this is feasible, before I try it and mess something up.
Any recommendations will be greatly appreciated.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 06-14-2010, 05:20 PM   #2
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: Front Brake hose removal ???
I had a heck of a time with mine. I ended up stripping out the fittings on the lines even with a flare nut wrench and a flare nut crowfoot wrench, and they never broke loose. I eventually gave up, and replaced mine when I did my motor mounts and some other stuff that made it all easier to access.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 06-14-2010, 05:27 PM   #3
mbgmike
I generally cut them all off with a die grinder. Its a pain. Brake fluid is flammable but I never had a problem with the lines drained
mbgmike is offline   Reply With Quote
