Old 06-14-2010, 06:47 PM   #1
michael bustamante
michael bustamante's Avatar
rubber brake line dilema
on my 67 I just converted to disc brakes off a 72, airbagged with factory control arms and relocated the brake line tabs to the front of the crossmember,
Question: it seems the rubber brakes lines are kinda stretched when the wheels is straight, Should I be using longer lines and if so, Whats recommended? I think another inch oughta do it but I could be wrong. the truck is still up in the air so now would be a good time to replace them if need be.
are the sqare body (73+) brake lines just a bit longer then the 71-72`s?
1967custom
michael bustamante is offline   Reply With Quote
Old 06-14-2010, 07:41 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: rubber brake line dilema
Pretty sure the '73 brake hoses are longer.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 06-14-2010, 07:46 PM   #3
vectorit
What?
vectorit's Avatar
I had mine custom made at an industrial hose supply house.
They took my originals, and duplicated them with the exact style hose and added an extra 2".
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 06-14-2010, 07:50 PM   #4
michael bustamante
thats what I thought I was gonna have to do, ok guys thank you
1967custom
Old 06-14-2010, 08:26 PM   #5
mbgmike
Superlift makes them 4" over stock for around $50.00 for a complete set. front and rear. Might be a little long for you
mbgmike is offline   Reply With Quote
Old 06-15-2010, 12:12 PM   #6
michael bustamante
yeah that would be a little long, I think 12" would be max length for me. what else have you guys used for brake lines on lowered trucks, Have you just used lines for like, lets say, a 77 1/2 ton 2wd?
1967custom
