06-14-2010, 07:46 PM | #1 |
3/4 dana 60 convert for a 1/2 ton 5 lug ?
3/4 dana 60 convert for a 1/2 ton 5 lug ? Has anyone done this? I have a 3/4 dana 60 with 3.54 gears I would like to use in 1/2 5 lug.
06-14-2010, 10:02 PM | #2 |
Truck and auto performance nut
Re: 3/4 dana 60 convert for a 1/2 ton 5 lug ?
I've been considering doing the same thing...but finding the right Dana 60 on the other hand, lets just say none have popped up yet.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
06-14-2010, 11:57 PM | #3 |
It is done all the time. You will need a longer drive shaft. If you can get the 1/2 ton drive shaft, you can just pull the 3/4 T shaft off of the slip spline and slip the 1/2 T on. Yep. It can be that simple. Check out Longhorn Man's suburban threads. He did just this, 3/4 D60 to 1/2 GM12 bolt. Unhook the brakes, unhook the shocks, unbolt the diff. Swap and re-install.
I swapped from a 12 bolt to a D60 6 lug. Just the opposite of what you are doing, swap wise.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
06-14-2010, 11:59 PM | #4 |
Big Red - Now its a SWB!
The 3/4 version is a full floater with the hub protruding out from the center of the wheel. The hub is too big to fit through a 5 lug wheel. there is no way to convert to the semi floater 1/2 ton version except to swap rears. like stated above 1/2 ton D60's are hard to come by and most are 6 lug if I remember correctly. You also need to remember that there is leaf and coil configurations. Some also say that the 12 bolt rear is stronger, and it is definitely easier to find. Good luck and let us know what you end up doing.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's Last edited by Jacfourteen; 06-15-2010 at 08:24 PM. |
06-15-2010, 01:51 PM | #5 |
specs wise the Dana 60 is stronger....and the car 12 bolt is also stronger then the truck 12 bolt. The truck 12 bolt has a smaller pinion shaft then the car 12 bolt.
06-15-2010, 01:58 PM | #6 |
Hey Jesse, I'm in poulsbo too!
I'm working on converting my 69 to 5 lug, but I got a complete 1/2ton suspension to do mine. |
06-15-2010, 04:26 PM | #7 |
its all about the +6 inches
the 3/4 ton danas are strong in the diff, but have junk axle shafts that shatter. So as a whole unit, they are not strong at all.
06-15-2010, 08:25 PM | #8 |
So what if you changed to aftermarket axles? Would this help the overall strength of the unit?
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
06-15-2010, 08:30 PM | #9 |
this may be true...but considering many would replace the axles as part of the swap/upgrade (at least I would be) makes it less of an issue.
06-15-2010, 09:33 PM | #10 |
My friend just cut the axle tubes from a full floater a dana 60 off welded on some new bearing retainers from moser as well as some of there 35 spline axles with 5 lug and a truetrac diff ,then installed it in his 67 camaro it is big and there will be no way that he will break it. The axles look so big that I am going to copy what he did and in stall one in my 68 half ton
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! |
06-15-2010, 10:19 PM | #11 |
it's the spline count that is actually the issue... 28 if memory serves. The axle is what shatters. As stated, the D60 is a stout diff, just GM picked the worst ones for the job.
06-15-2010, 10:54 PM | #12 |
Cool Truck
I thought this guy wanted to put a D60 in a 1/2 ton, not a 5 lug rear on a 3/4 ton truck.
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
06-15-2010, 11:08 PM | #13 |
didn't do it on the Dana, but I swapped my Corporate 3/4 ton rear for a 1/2 ton 5 lug on my old 72 burb
06-15-2010, 11:09 PM | #14 |
Okay, I didn't catch that. I thought he was going the other way. Yeah if he wants to do that it's not that hard. Just have to swap drivelines like stated above. Not sure why you'd want to though, I want to get rid of the D60 in mine and swap to 5 or 6 lug to get rid of the big hub sticking out.
06-16-2010, 01:01 AM | #15 |
I wanted to take my dana 60 weld coil spring brackets some how get rid of the floater axles and end up with regular 5 lug set up. I was under the impression that a dana 60 was way stonger than the 12 bolt. Hey ACKATTACK let me know if you have any parts for sale or trade.
06-16-2010, 07:18 AM | #16 |
He wants to take an 8 lug dana60, and convert that rear axle assembly to a 5 lug rear.
06-16-2010, 09:30 AM | #17 |
new axles from Moser are a fair price.Give them a call and let them know what you want to do, they would be able to help out. I would ask my friend but is in training with the reserves and I can't get a hold of him at this time to ask what type of bearing retainers he used on the axle tubes.
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!! Last edited by Willys47; 06-16-2010 at 09:31 AM. |
06-16-2010, 04:39 PM | #18 |
The hubs would have to be cut off, new flanges installed, custom axles, source a brake system, and a big steaming pile of work. If you really just want strength, get an aftermarket 9 inch. You can get it exactly like you want it.
