06-15-2010, 01:01 AM | #1 |
maybe this could be my problem?
as many of u as seen in many of my threads about my stalling problem.. my dads friend is a mechanic for many many years.. he was saying if i rev up to max or whatever in park you cant tell what im about to say but when u rev up to max in neutral and it bogs a bit it maybe my rear end? whats he talking about there? he says the stalling out problem could be my rear end going out if i dont have junk in the tank
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
06-15-2010, 04:45 AM | #2 |
Location: Aurora,Il ..born,raised and still live in the same house
Re: maybe this could be my problem?
that'a new one.
never heard anything like that before.
I love stock! Not really into the whole bagged, squished,chopped, drooped,cut, bent,lifted,twisted,split,decked,massaged,tubbed,jacked trend. (o.k. slightly lowered is fine) For the love of god, just drive it before you forget what the truck is supposed to look like !....LOL |
06-15-2010, 06:45 AM | #3 |
i'd clean the tank first
06-15-2010, 09:00 AM | #4 |
?????????? How is that even related? If the truck is in neutral the rear end is not a factor at all, that would lead me to believe that you have one of three issues, timing, fuel or air. Not much it can be other than those. What type of carb do you have, what is the timing set at? have you place the dist. on a dist. on a actual dist. machine to check advance etc. What type of breather, plug wires good, are they cross firing at rpm, something is breaking down. Have you over reved the engine? valve springs could be clapped out. Lots of choices that you have but you just cant swap parts you are going to have to diagnose and be specific.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
06-15-2010, 09:33 AM | #5 |
Active Member
I think what the gentleman was trying to say is that if it doesn't bog down while in park or neutral, than something else is causing the problem. Can't say that I agree though.
As mentioned above, ignition components, timing and fuel delivery are the main causes of bogging at certain speeds. If fuel delivery is restricted it just won't get enough fuel to go any faster. Since this is an ongoing problem and getting worse, start by making sure you have good, constant fuel delivery. Here's some things I've encountered with these old trucks. Fuel tank filter, carb filter (insure it's installed properly with spring behind the filter), fuel pump pressure. Pumps are cheap so if it's never been replaced, try another one. Fuel lines restricted internally. Mine was so restricted that eventually it stopped running. Had to replace the one from the tank to the fuel pump. Finally, a severly worn cam may cause what seems to be bogging since the valves won't open enough to allow the engine to breath or run at it's max efficiency. |
06-15-2010, 10:02 AM | #6 |
I don't know if your corrupt state has forced the crappy ethanol mixed gas on you like ours (MO) has, but this stuff is murder on rubber lines. It could very well be that your rubber gas line has collapsed on the INSIDE, while it looks OK on the outside.
I've had no end of problems because of this. |
06-15-2010, 10:32 AM | #7 |
Check also for a restriction in the exhaust system, someone might have stuck a tater in your tailpipe.
1972 GMC Jimmy, 4WD, 454 CI, 350 Turbo, 4" lift, 35" tires The math teacher said my son "Bubba" could be a mathmatical genius. cause he's got 13 fingers! |
