Old 02-15-2003, 11:20 PM   #1
Growdon
? about steering box leak
My power steering box is leaking around the input shaft. The box appears to be alright otherwise. I am in the process of replacing all front suspension parts and would like to take care of this leak at the same time. Is there a bushing/ seal available, or do I have to buy a reman. steering box. Any input would be appreciated.
Thank You,
72 K5 CST 350/350. 4 wheel disks, 4" lift soft top. ###Sold
71 GMC Custom K2500, 3/4 ton 4x4. 350/350 ## Just bought, New Project
Growdon is offline   Reply With Quote
Old 02-16-2003, 12:50 AM   #2
minibike
minibike's Avatar
There are seals available for the input and pitman shaft. I just bought the pitman shaft seals yesterday, and the local autozone had both seals in stock
69 SWB
LT1/4L60E
www.classicplace.com
minibike is offline   Reply With Quote
Old 02-16-2003, 03:00 AM   #3
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
how much did those seals run you. Mine has leak on both ends.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 02-16-2003, 05:49 AM   #4
Hooter
My other Love
Hooter's Avatar
i dumped some tranny stop leak into my 77 chevy power steering resivior two years ago, and it hasnt leaked since
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 02-16-2003, 09:55 AM   #5
minibike
minibike's Avatar
You can go to www.autozone.com and check pricing, but the lower set of seals (there were two in the box) are around $8.
69 SWB
LT1/4L60E
Old 02-16-2003, 12:04 PM   #6
Growdon
Thank you guys, I figured there were seals available, but have no experience with steering boxes.
Old 02-16-2003, 04:40 PM   #7
minibike
minibike's Avatar
OK...I'm trying to get the old seals out....anyone have some advice. I read in my book that you can turn the wheels all the way to the left with the engine running to get them out. My truck is not running yet, and I want to replace the seals because they leak...help!
69 SWB
LT1/4L60E
Old 02-16-2003, 04:49 PM   #8
blazunfool
Yes normally with the truck running you could loosen the nut and jerk the wheel one way are the other a couple of times and it would blow the seal out and you could repace it.
Since your truck is not running yet you may try drilling a small hole and use a small dent puller to pull the seal out.
72 2wd Blazer 305TBI/700r4., 69 C10 SWB 400SB TPI, 400trans, Step side ., 72 4WD Blazer 350 TBI, 350 serp. drive & "Old Air" ., 94 Camaro Z28 LT1., 94 Grand Cherokee V8, 95 Grand Cherokee 6cyl.
blazunfool is offline   Reply With Quote
Old 02-16-2003, 05:44 PM   #9
minibike
minibike's Avatar
Excellent idea...I just tried it and it worked.
69 SWB
LT1/4L60E
Old 02-16-2003, 11:31 PM   #10
blazunfool
I am glad to see that worked for you, I hope it helps others on the board.
Old 02-17-2003, 03:14 AM   #11
Hotrod70C10
Low & Slow
Thanks guys. I put some trans-x stop leak in it about a year ago and it slowed it way down but it still leaks. I will replace the seals when it warms up some.
4.5/6 drop
