Old 06-15-2010, 10:46 PM   #1
67chevy1series
67chevy1series's Avatar
04 chevy tahoe rear axle on 67 1/2 ton coil
ok my idea is to get a 03 to 06 chevy tahoe rear axle with disc brakes added on stock cut the leaf mounts weld coil mounts on cut shock mounts cause coil has the shock mounts on bottom of trailing arms so what i wanna know is the axle tube fatter or skinnier then 67 72 stock and from wheel to wheel is it longer or shorter or the same in advance thanks
67chevy1series is offline   Reply With Quote
Old 06-15-2010, 11:23 PM   #2
SCOTI
SCOTI's Avatar
Re: 04 chevy tahoe rear axle on 67 1/2 ton coil
I'm not sure about the axle tube OD but the late model rear is definitely wider than the 67 12-bolt housing.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-15-2010, 11:31 PM   #3
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
tahoes have a 4 link with coils, not leaves. I'm not sure what the axle tube O.D. or overall width is but I could measure mine tomorrow. I had also pondered this but I wanted to adapt the tahoe 4 link onto my truck so I could get rid of the leaf setup.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 06-16-2010, 04:53 PM   #4
67chevy1series
thank you jacfourteen
Old 06-16-2010, 05:48 PM   #5
capev86
you don't need to "add" disc brakes....they were factory equipment after 2000. use the front disc system too and you will have modern (factory) 4 wheel disc with 6 lugs....you could hide them under stock or retro wheels ofr the stealth look. and the wider rear axle will look awesome since gm trucks always have a narrower track width on the back than on the front
capev86 is offline   Reply With Quote
Old 06-16-2010, 06:09 PM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
I did a quick guestimate of the width hub to hub on my silverado and it looks to be 68-69 inches, which is significantly wider than my 67. You also have to remember the 99+ trucks run rims that have a ton of offset, to have a wider, more stable track width.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 06-16-2010, 06:30 PM   #7
67chevy1series
ahhhh sh@# that sucks oh well rear drum and front disc is fine ill just stick with that
