Old 06-15-2010, 11:24 PM   #1
spankbomb
Shockwave 9000 or 9001 Eye/Bolt Size
Quick question, I've searched both here and the ridetech site. What size bolt (diameter) is used for mounting the above bags and is a bushing sleeve required (if so, what size)?
TIA,
Jon D.
www.eastofaustin.com
spankbomb is offline   Reply With Quote
Old 06-15-2010, 11:41 PM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: Shockwave 9000 or 9001 Eye/Bolt Size
TIA,
Jon D.
Last I checked, they were eliminating the poly bushings and using spherical bearing instead. I would call them to verify.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 06-16-2010, 08:38 AM   #3
spankbomb
The spherical bearing appears to be 1/2 and I found that they do use a sleeve in the poly bushing (which the sphericals look like the better way to go in order to avoid binding.
http://www.ridetech.com/new_shop/sus...d-sleeves.html
Thanks for the info.
Old 06-16-2010, 12:05 PM   #4
spankbomb
I went ahead and ordered the 1/2" sleeves from Craig at ridetech. After hitting two auto parts chains and one hardware store (not a Lowe's or HD, one with a real fasteners aisle), I threw in the towel.
$17 for four shipped is cheaper than running all over Central Texas.
Later,
Jon D.
