02-16-2003, 01:11 AM | #1 |
Failure is NOT an option!
windshield removal
how can i take my windshield out with out destroying the chrome trim or busting the glass,never tried before, thought i might ask first
02-16-2003, 02:50 AM | #2 |
huh ???
The easyiest way is to cut through the windshield gasket on the inside. Then the glass can be lifted out. Get a friend to help though.
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
02-16-2003, 08:52 AM | #3 |
PROJECT 7DEUCE
Also the chrome trim comes off after the removal of the glass so dont pry on the trim ...Theree was a post awhile back on this..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
02-16-2003, 11:47 AM | #4 |
How deep should you cut, what do you use. I have seen glass guys use a piece of wire with two handles on it to cut the gasket, is this the way to go???
97 ext cab 4x4 04 pontiac grand am 05 honda rancher AT (yellow) 71' C-10 swb sb400 th350 .040, 292 Mag comp cam, high rise Edelbrock w/750 duel feed Holley, Accel super coil and wires, B&M ratchet shifter |
02-16-2003, 01:20 PM | #5 |
"Ochre Ogre"
Use a carpet knife. I like the blades with the hook cutting edge, but any razor sharp cutting edge will work. From the inside of the cab, peel the rubber away from the cab. You will see how the rubber wraps around the steel. All you need to do is slice it at the top and down the 2 sides and the window will come out.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
02-16-2003, 05:38 PM | #6 | |
1969 Custom 30 wrecker
I managed to remove this trim in a junkyard this past summer. I needed the trim but the windshield was still in so... I just took my time and managed to get it out without any damage. Of course, I wouldn't recommend doing this normally but in this case, I knew the junkyard owner wasn't going to pull a windshield to sell me a few chrome pieces.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
