Old 06-16-2010, 12:44 PM   #1
DirtyDrew
DirtyDrew's Avatar
bouncing truck
why does my truck bounce so much? i have two 07 gmc trucks and they are so bouncy and jumpy. they handle like crap and when i hit bumps in the road it seems like the tires hop off of the ground. i put 22"rims and that helped a lil bit, lowered the back 2" and that did nothing to. I have a 98 chevy truck and that thing is glued to the ground! it takes corners going 45 with no tire screech and rides like a champ! I just dont get it.
66 chevy shortbed fleetside
73 camaro
98 chevy pickup
DirtyDrew is offline   Reply With Quote
Old 06-16-2010, 03:07 PM   #2
truckdude239
truckdude239's Avatar
Re: bouncing truck
please watch the language this is a family site and there's no need for it
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 06-16-2010, 03:17 PM   #3
71swb4x4
71swb4x4's Avatar
Re: bouncing truck
Have you modified the suspension at all? Different shocks? Sprnigs?
What size tires do you have? Tire sidewall does a lot to cushion a ride. With a small sidewall you will feel more from the road.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-16-2010, 06:24 PM   #4
DirtyDrew
DirtyDrew's Avatar
Re: bouncing truck
no mods to the front suspension, 2 inch lowered in the back with shackle, 305/40-22 and i have a totaly stock truck as well with the steel rims. the truck with the rims and tires rides a little better than the fully stock truck
73 camaro
98 chevy pickup
Old 06-16-2010, 09:31 PM   #5
clinebarger
Re: bouncing truck
Have you checked tire pressure? Factory shocks are junk. Look into some Bilstein shocks for both your trucks.
I agree with 71swb4x4 big rims & lower profile tires will have a worse ride than a stock set-up.
clinebarger is offline   Reply With Quote
Old 06-23-2010, 11:37 AM   #6
michael bustamante
michael bustamante's Avatar
Re: bouncing truck
2wd? 1/2 ton? 3/4 ton? I gotta agree, change the shocks for a better ride. I switched my 3/4 ton to KYB and Its a noticable difference, especially when not towing
1967custom
michael bustamante is offline   Reply With Quote
