Old 06-16-2010, 03:16 PM   #1
Chionos GMs
Chionos GMs's Avatar
Crew cab project help
I have a potential project truck that I can get for dirt cheap it is a 1984 crew cab 1 ton 2wd 6.2 diesel dually. It was my granfathers truck he was original owner. My questions are: How hard would it be turn the dually longbed to a shortbed dually? How hard is it to go from the diesel to a gas engine? I had an idea that GM guys didnt like I wanted to put a 7.3 Powerstroke in it . Last question I have seen some clear tail lights and was wondering where I could get a pair?
Chionos GMs is offline   Reply With Quote
Old 06-16-2010, 03:55 PM   #2
csa daddy
csa daddy's Avatar
Re: Crew cab project help
i wouldnt do the power stroke at all ive road in them an if i was going to go threw all the trouble i would do a cummins or a durmax or even a 6.5 turbo but not the powerstroke. an as far as cutting it down to make a short bed it aint nothing but to get out there an figure out how much needs to come out of the frame to shorten it where you need. then just cut the short bed sides for the flares check out my build in the project section
csa daddy is offline   Reply With Quote
Old 06-16-2010, 04:01 PM   #3
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
If you wanted to be different, I'd use a 7.3 psd no problem. They can make nice power and still get good mileage. Just get a complete donor truck and use everything from the donor truck. On the frame, I'm sure you need to take some out of the front and rear to make the tire centered in the wheel well.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 06-16-2010, 04:02 PM   #4
Chionos GMs
I was goin to cut down the bed I already have. Is it worth it or just use a shortbed?
Old 06-16-2010, 04:04 PM   #5
Chionos GMs
I was goin for something different thats why I was thinkin of Powerstroke
Old 06-16-2010, 04:09 PM   #6
Dieselwrencher
Ok, I'm wrong. Go here and you can see where the frame was cut to shorten the frame. http://www.67-72chevytrucks.com/vboa...d.php?t=407743 I'm guessing this is where everyone cuts these to make them short beds. I'd say you would be way farther ahead just getting a short bed unless you are a great welder and have a lot of extra time. And don't let the chevy guys discourage you on the powerstroke. They are made by international, not ford. They'll get over it.
Ryan
Old 06-16-2010, 04:33 PM   #7
Chionos GMs
I do have alot of free time till school starts for me. Im not a great welder but I know what im doing. I like the idea of the Powerstroke cause it is different and I have been raised around International trucks. Thought it would be cool
Old 06-16-2010, 04:58 PM   #8
csa daddy
csa daddy's Avatar
i know some of those power strokes had some major problems. an yes use a short bed to start will be alot easier cause if u use a long bed you have to cut the front an the back of the bed.but what ever power plant u use it will be unique cause as far as i know this will be the only other shortbed dually besides mine that i know of
Old 06-16-2010, 05:14 PM   #9
Chionos GMs
I like a 6.0 gasser, Cummins thinkin a newer one, or a dmax. But I was thinkin to put a 6.2 or 6.5 and make it like Chevy would have from the factory!
Old 06-17-2010, 10:16 AM   #10
csa daddy
csa daddy's Avatar
myself personaly i like the 5.3 it has about as much power as the 6.0 but gets a little bit better gas mileage. now as far as the dmax an cummins both will be a major undertakeing to do. the 6.2 an 6.5 shouldnt be hard to do at all
Old 06-17-2010, 02:00 PM   #11
Chionos GMs
6.2 and 6.5 will be super easy because it has a 6.2 in it right now
Old 06-17-2010, 05:43 PM   #12
csa daddy
csa daddy's Avatar
why dont u just turbo the 6.2 its about the same motor as a6.5 i think you might need the heads of the turbo motor to do it not real sure
Old 06-17-2010, 05:54 PM   #13
Chionos GMs
Yeah I have 2 of these 6.2 but this engine is no good. so it needs a new one
Old 06-17-2010, 09:06 PM   #14
csa daddy
csa daddy's Avatar
right check out http://www.dieselplace.com/forum/forumdisplay.php?f=63 an they probly can give you the best info on about any swap you could want to do
