Old 06-16-2010, 03:47 PM   #1
4montecarlo
remove window
on my 84 with electric windows, i replaced the door, but now realize i want the window glass for my new door. can i pull the window out with it rolled up or will i need to supply power to window motor to lower it?
thanks
matt
4montecarlo is offline   Reply With Quote
Old 06-16-2010, 03:54 PM   #2
pseudopimp
pseudopimp's Avatar
Re: remove window
i think you might be able to remove the regulator and the window without rolling it down. might be more difficult that way
84 Scottsdale LWB K10
Rooting against the cowboys is almost as fun as rooting for the GIANTS!
pseudopimp is offline   Reply With Quote
Old 06-16-2010, 05:27 PM   #3
4montecarlo
Re: remove window
thanks
i will try to route power to it
matt
Old 06-16-2010, 05:54 PM   #4
grinch4om
dang its hot
grinch4om's Avatar
Re: remove window
you have to lower it
grinch4om is offline   Reply With Quote
Old 06-16-2010, 06:13 PM   #5
bikes&bowties
bikes&bowties's Avatar
Re: remove window
if you remove the motor you can lower it without power
bikes&bowties is offline   Reply With Quote
Old 06-16-2010, 06:48 PM   #6
silvereagle07
silvereagle07's Avatar
Re: remove window
Don't try this! The regulator lift arms will spring up when you remove the motor because it has a tension spring to help the glass go up. If you unbolt the window and take the motor off it will spring up and cause damage.
Just lower the regulator, slide the sash reaward to disengage the rollers. Then remove the window glass.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
