06-16-2010, 09:03 PM | #1 |
Disc Brake Question.
Will 73 to 87 upper and lower ball joints fit into 70 model control arms. If so could I buy 73 spindles, rotors,calipers,bearings,outer tie rods,and tie rod adapter from CPP to give me disc brakes on my 70? Or is there an easier and cheaper way.
06-16-2010, 09:18 PM | #2 |
Re: Disc Brake Question.
Vanceman, I am contemplating doing the same thing on my truck, I think what you are trying to do would work exactly as you have it stated. might be able to save a few $$$$ and junkyard the spindles and local source the rotors and bearings etc may save you a few bucks that way instead of buying the kit
06-16-2010, 09:46 PM | #3 |
I have been doing some research and I think this will really work and save me some money. I just can't see paying $800 for this. I hope someone will chime in that has done this. Any help, tips, or advice will be greatly appreciated.
06-16-2010, 10:11 PM | #4 |
67-72 parts collector,…
They will work in the older control arms.
06-16-2010, 10:15 PM | #5 |
You will have to address the outer tie rods.
The 73+ outer tie rods will be required. The problem is they are larger and the wrong thread direction. You need a tie rod adapter sleeve to connect the 11/16" 73+ outer to a 67-70 inner. (It's only 5/8" diameter and the wrong thread) To cure this,... you need to use a 67-70 outer tie rod as an "inner" tie rod. I did all of this on my '69. Get the "conversion" tie rod adapter sleeves from www.performanceonline.com.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 06-16-2010 at 10:15 PM. |
06-16-2010, 11:04 PM | #6 |
Unless you really enjoy greasing the stock control arm bushings, I would suggest taking the control arms and shafts from the donor truck also. These have rubber bushings and are maintenance-free. If the 73-up bushings ever do require replacement, they cost a lot less than the 72-earlier type.
Ray |
06-17-2010, 06:13 PM | #7 |
Has anybody bought a disc brake conversion from POL, they seem to be cheaper then the others. If so how the quality of parts?
06-17-2010, 07:40 PM | #8 |
Is it just possible to take the center link and avoid the whole issue with the tie rod ends all together? And just change the pitman arm on the box? Just a thought and a curiosity on my part as well for my swap
06-17-2010, 08:29 PM | #9 |
Take the 73-87 center link and all the tie rods, would definitely be a better/cheaper route.
06-18-2010, 01:27 AM | #10 |
