Grandpa in the rustmobile...
Help! Filler on blazer tank should I cut hole in floor
I have a blazer tank with a adaptor goin from 1 3/8"-2". If I lower my bed onto the frame my filler will hit the floor. Should I cut a gaping hole in the floor (to the left of the bed mounting hole,just over 2") Or figure out a different plan..thanks!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
![]() Join Date: Sep 2007
Re: Help! Filler on blazer tank should I cut hole in floor
from what Ive read (and I havent put my bed back on yet) you have to notch the cross rail on the bed to make clearance
1967custom |
I already did.....
No what I did was I welded an adaptor on (because I cannot to save my life find 1 3/8" FUEL hose anywhere!) but now my adaptor is too high up and will go thru the floor.. ![]() and ive already put gas in it (no welding lol) thanks ima bout to cut a hole in the floor and say f it I took the thread part of the filler and heated it up to loosen the solder and was going to try to slip it in my existing adaptor but it was just a tad to small and for you guys running a short fuel filler do you have trouble with 'sloshing and leaking?" thanks a ton this is a pita
getting ready to do this so I bumpin it back up top
found this while reading old posts
saw this at the oreillys but it wasnt radiator hose OR fuel hose would something like this hold up or what? somebody else used it.. ima get on paint and play around
![]() Join Date: Jul 2009
I think it will work. its not like fuel will be stored in the hose. its just used to funnel it into the tank
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
Has more rust than truck...
Can't you just bend the filler with the adapter down?
The only place I found the hose was a Specialty marine store. Its rated for fuel and exhaust. |
I could but the adaptor is like 2.5" long PLUS the stock blazer tank filler...
i'll check marine websites thanks! will that^^^hose work and if i wanted to cut my adaptor off how would I keep metal shavings from going in the tank thanks
#9 | |
For cutting the adapter off, use a round cleaning brush shoved down in the filler neck while you cut. Have someone running a shop vac while you cut and there shouldn't be much down in the tank when you pull out the brush. Don't cut the brush handle. |
^^that brush woulda been a good idea
i stuffed a damp rag down in it and then made the cut it worked pretty good then had a piece of metal cut and welded at the muffler shop and some kid practicing welded it (i coulda done better) but i told him what i wanted, which was not wat i watned lol so im scrapping the idea and going to try to make something out of galvanized pipe that we have in the barn ima do a filler in the bed infront of the tailgate post on the drivers side Its gonna be a L with the top of the L being the cap, and the lower part of the L being my adaptor going to 13\8 i'll try to get pics its discouraging i havent drivn my truck in like a month lol i just am tired of WORKING on it..lol
get some fuel hose for your filler nech and use a BOAT FUEL FILLER SETUP.. they make all kinds of different ones... that way atleast it will be presentable in the bed....
http://www.google.com/products?rls=c...ed=0CDoQrQQwAg Last edited by QKENUF4U; 06-18-2010 at 07:48 PM. |
I got some flexible 1 1/2" Fuel hose from napa and it seems to fit with a nice hose clamp tightened down to really snug it up on the blazer tank neck. I'm using a marine style filler on the wheel well inside the bed for a filler. Hopefully the tire won't rub lol my son just got done lowering it and we are running out of space!!! Is it safe to tighten down on a 1 1/2" inch hose to make it snug? I saw several vendors had 1 3/8" hose the problem is that all the marine filler necks are 1 1/2. BTW 1 1/2" Belted Flex Fuel hose is $24 a foot at napa LOL. I paid for 2' and only got 22".
#13 |
Your UncleBen
![]() Join Date: Dec 2002
Would love to see some pics of how you guys are doing the filler necks....I am pondered on what to do myself! HELP!?
lata CHRIS
68 C10 shortbed -- Street/Strip ![]() |
#14 |
Sidemarker fill on my 71.
Great minds think alike,So do ours |
#15 |
Ooops I re read that. Here's what you want. We went to a muffler shop had them make a new filler neck & relocated it so it would be easier & straighter for filling.Went with a gas hose that has a grounding wire in it to prevent static electricity while filling up.
Great minds think alike,So do ours Last edited by chevyboy55; 06-20-2010 at 11:02 AM. |
#16 |
Chevy Lover Till The End.
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011 1989 Chevy Silverado, 4X4 - Daily Driver 1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck 1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original. Members I've met: BamaBaxter, My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359 |
#17 |
Your UncleBen
I like your idea. Hopefully I was trying to not have to weld on this tank! Hahah Anyone using the stock fill location? If so lets see how you handled it! Thanks guys!
#18 |
Your UncleBen
BTW...Beautiful truck and sweet side marker fill....
#19 |
that hose will work fine. it is a oil suction hose. check out my filler idea. i had som 1 1/2 exhast pipe bent and i cut and pieced the pipe to the backup light. it works great.
#20 |
Your UncleBen
Not bad! I like the idea. How did you mount your tank?
BTW...In the last pic... Is the pipe missing a piece??? Or is that just an odd pic? lata CHRIS
#21 |
Hey crusher Does your lense go on there too?
If I come to murfreesboro will you help me do mine like that lol this sucks its tricky lol going to muffler shop tomroow to talk to him..AGAIN
#22 |
yea sweetandlong68 i had to notch out the pipe to clear the side marker. it dont affect the fuel flow too much angle there. the tank is mounted under the back. it is a blazer tank.
old blue come on ill help you. i havent gotten my lens mounted permantly but it will be shortly just have had other things going. Last edited by crushermechanic; 06-20-2010 at 08:14 PM. |
#23 |
chevyboy, where did you get the hinge? can I get some info and more pics.
thanks Sidemarker fill on my 71. Attached Images __________________ Great minds think alike,So do ours |
#24 |
Moderator
![]() Join Date: May 2007
I started off with the sidemarker idea....but quickly realized this would not work where I live. The gas pumps have a large rubber "boot" on them and the filler nozzle will not fit inside the marker cut-out. I used a Blazer filler and cover, turned it around 180 degrees, and cut out a hole in the cover for the filler to stick out through. I also used a 60-66 rubber gasket (it is angled so it works better with the angle of the filler neck) It looks factory. Here are some pics of it. I have more at home, and a pic of it complete. The filler is up high so there are NO problems with fuel backing up and spilling out.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man Last edited by leddzepp; 06-22-2010 at 12:53 PM. |
#25 |
thats what im doing^^ minus the cover....now i just gotta get back to work i'll post pics when im done it should polish up good
