Old 06-17-2010, 06:28 PM   #1
EZTHERE
How do I pull the engine.
im ready to pull the engine but having a problem getting the wrench around the eng mount bolt. seems the rubber mount is squashed and pressing up against the mount bolt that goes into the block. Is this the only way to pull the motor or do I remove that wacky cross member set up. ??
EZTHERE is offline   Reply With Quote
Old 06-17-2010, 09:05 PM   #2
jamie72
jamie72's Avatar
Re: How do I pull the engine.
first off, what are you working on, 2wd or 4wd?
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 06-17-2010, 11:21 PM   #3
JimmyFloyd
on the 4x4 K20 I had, you remove the center bolt from the mount from the bottom and it separates the two halves and allows the motor to be removed.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3
JimmyFloyd is offline   Reply With Quote
Old 06-17-2010, 11:52 PM   #4
EZTHERE
Its a 4x4. Thanks Jimmy. also let me confirm I need to support the 4sp tranny when I pull the engine bell housing as a unit.
