06-17-2010, 08:04 PM | #1 |
Check The Champ, Demonstrator
Rubber load helper. Do you have any?
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 Last edited by aerotruk63; 06-17-2010 at 08:05 PM. |
06-17-2010, 11:22 PM | #2 |
60-66 Nut
Re: Rubber load helper. Do you have any?
I know this isn't OEM stuff, but you could fabricate the mount and use a rubber bumper from these guys.
http://timbren.com/
06-18-2010, 05:42 AM | #3 |
Contacted Timbren during the winter, they supplied the rubber to GM but not the bracket.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
06-18-2010, 06:26 AM | #4 |
1961 crewcab
next time I am at kellys I will look to see if there are any, do you need some, or just want to see them on a truck?
coil, or leaf?
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
06-18-2010, 06:28 AM | #5 |
1961 crewcab
I think my 65 has something similar to that , but they are a coil, not rubber.
06-18-2010, 06:12 PM | #6 |
I would like to have either or both. I would like to measure the sizing of the Timbren, then get a replacement.
When I contacted Timbren they stated that the rear kit for the K10, would be GMRP30 model and that there should be some spacing. The stock front of the K10 uses the same snubber as the stock rear C10 coil spring, therefore I assume GMRC10A. Timbren says that the front should be in contact at all times.
06-18-2010, 10:37 PM | #7 |
1961 crewcab
here is what is on my 65, dosen't look like I am using them, I can't see any spot where they have touched the frame
my gmc 3/4 has the extra spring pack like the pic on the top right.
06-19-2010, 12:11 AM | #8 |
I have a set of these on mine:
06-19-2010, 05:36 AM | #9 |
rendus has the optional helper leaf springs. jonzcustomshop those must be aftermarket.
06-19-2010, 08:07 AM | #10 |
Sweet, thanks for the info...
I bet my special spring lubricant is loooooong gone! Last edited by rendus; 06-19-2010 at 08:08 AM. |
