Old 06-18-2010, 11:03 AM   #1
PatronMotorsports
PatronMotorsports's Avatar
LMC Headlight Upgrade Wiring Harness
Has anybody tried to hook up this kit The LMC kit is not a direct R&R and there is no way to connect their harness(3 Blade) to the trucks 2 Blade connector. LMC is clueless and suggests calling Taiwon and asking the Mfg.
Thanks in advance
PatronMotorsports is offline   Reply With Quote
Old 06-18-2010, 05:00 PM   #2
dallas71
dallas71's Avatar
Re: LMC Headlight Upgrade Wiring Harness
Which kit did you buy??? I did a couple of years ago and i didnt have to modify nothing.
dallas71 is offline   Reply With Quote
Old 06-18-2010, 05:40 PM   #3
PatronMotorsports
It's the 100/90W Hi-Grade Head Lamp Tune Up KIT P/N 36-3580.
Looks like we both have 66 Chev LWB Trucks
Old 06-18-2010, 08:55 PM   #4
TR65
TR65's Avatar
I purchased that kit too and I expected the connector thru the radiator support to be the factory connection but it wasn't as you found out.
I basically stripped out that harness and used the wiring, the headlight connectors and the relays. I bought a harness from Classic Industries to get the correct connector. Here is what I did.
http://67-72chevytrucks.com/vboard/s...d.php?t=397695
You do need three wires through the radiator support because you need a new power wire since the old two wire rig just operates the relays, doesn't carry the headlight power.
I shoud have sent the LMC harness back but I made do.
Good luck,
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 06-18-2010, 11:28 PM   #5
PatronMotorsports
Thanks a lot TR, Just what I was looking for. And the explanation makes sense too. Kind of makes you wonder why LMC hasn't posted a work-around.
Old 06-18-2010, 11:42 PM   #6
Fred T
Cantankerous Geezer
Fred T's Avatar
No workaround because they don't have a clue. All they do is sell parts. I recommend buying from a business that uses what they sell.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 06-19-2010, 07:38 AM   #7
PatronMotorsports
Sometimes their catalog is good for solving assembly issues, their blow-up pix are pretty accurate. Saves dragging the assembly manuals out into the shop. But I'm afraid your right, their fitment and tech support are not always up to par.
Old 06-19-2010, 07:18 PM   #8
McC_65_91
McC_65_91's Avatar
did one a while ago on my 65 gmc, its 4 head lights. i dont remember much about doing it but it still doesnt work right. The high beams run all the time but dim when i set it to low beams, (where they should go off right??). I thought maybe i used high/low beam bulbs for the high rather than just high beam bulbs, but thats not it, dunno what else it could be,but i can deal with it, dont drive it at night much anyway
McC_65_91 is offline   Reply With Quote
Old 06-19-2010, 09:25 PM   #9
TopFuel1966
TopFuel1966's Avatar
I believe the 36-3580 harness is meant to be used with the halogen bulbs which take a 3-prong connector.
TopFuel1966 is offline   Reply With Quote
Old 06-19-2010, 10:21 PM   #10
TR65
TR65's Avatar
Top,
The bulb connectors are correct, the third prong is for the ground.
The issue is the connector thru the radiator support. It won't fit the stock hole, and they don't give you the mating connector.
TR
1965 C10 SWB Fleet
Two owner
Old 06-19-2010, 10:43 PM   #11
TopFuel1966
OK.........I was looking at the wrong end of the harness.
Old 06-20-2010, 06:46 AM   #12
apachedaddy
apachedaddy's Avatar
I wouldnt think the connector would be an issue. Most people that are doing this swap should or one would think they would have the factory harness. Why can't you just use the old factor plug and put that on the new harness??
Or am i way off base here.
66 short wide fleet sbw = Gave to my best friend
66 short wide fleet bbw
apachedaddy is offline   Reply With Quote
Old 06-20-2010, 07:10 AM   #13
PatronMotorsports
In this case it would be impossible to plug a round rubber two wire plug into a much larger plastic three wire receptical. Granted I'm not sure what modifications may have been made to the factory harness in the last 40+ years. It still remains that I have found no one that has found the kit to be plug and play as advertised. In the meantime I'll cut it up and use what I can to make it work. Not something I would want my CE to have to do on my Longbow.
Old 06-20-2010, 12:38 PM   #14
markeb01
Senior Enthusiast
markeb01's Avatar
Did LMC happen to provide a schematic for their harness? It shouldn’t be that difficult to modify for use with the stock bulkhead connector. In the stock harness there are only 2 wires going to the lamps from the dimmer switch - 1 for high beams, and 1 for low beams. Ground goes straight from the bulbs to a sheet metal connection.
If the 3rd wire in the new harness is in fact ground, the terminals could be slipped out of the new coupler, reinserting the high and low beam wires into the original connector, and ground connected separately (assuming they used stock male/female terminal orientation). For maximum light output, the ground should be routed back to the battery ground either on the engine block or frame rather than screwed to sheet metal.
Assuming you’re intending to add relays to go along with the new harness, here’s a schematic in case you don’t already have one.
And here is the layout of the factory plug so the wire terminals end up in the correct slot:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 06-22-2010, 07:43 PM   #15
John Gilbert
You guys I think know where things went wrong. My guess is the stock headlight harness that runs on the '60-66 core support is being eliminated, instead of retaining and plugging LMC Truck's Heavy-Duty harness into it.
Here's a link to the story I just did for CCT on my '79 C10 using the Heavy-Duty harness. I've also included a shot of LMC's Heavy-Duty harness on my '88 C/K which hasn't appeared in a magazine tech. I looked under the hood of my '66 to get a better idea, but as you can see it's been stripped of all wiring.
The idea behind the Heavy-Duty harness besides improving light quality is to be reversible which means it easily unplugs and the truck can be returned to stock.
Here's some photos: If anyone would like an explanation of what's being shown, I'll be glad to expand on what I was trying to get across.
John Gilbert is offline   Reply With Quote
Old 06-22-2010, 07:52 PM   #16
John Gilbert
Oops, I can already see I had better explain what's here.
top photo: Looking straight down onto '88-98 C/K arrangement. I mounted the relays close to the battery, and LMC's plugs, plugged into existing GM plugs.
second from top: My '66 is stripped out, so I couldn't show what's involved, but I'm sure its not much different from the C/K or '73-87 C10.
Third photo is my '79 C10
Fourth photo shows how the stock C10 driver side plug is left hanging, and the Heavy Duty harness plugs directly into the headlight.
Here's the link http://www.customclassictrucks.com/t...c10/index.html
