Old 06-18-2010, 05:29 PM   #1
chevy49
chevy49's Avatar
M11 crosmember info?
will a stock M11 crosmember work on a 54 chevy truck frame ? if so with what mods?
chevy49 is offline   Reply With Quote
Old 06-18-2010, 05:52 PM   #2
raycow
Re: M11 crosmember info?
You mean one that actually came out of a Mustang, instead of an aftermarket one?
Ray
raycow is offline   Reply With Quote
Old 06-18-2010, 06:10 PM   #3
chevy49
chevy49's Avatar
yes that is what i am talking about.i have instaled one in a 1940 chevy car.
Old 06-18-2010, 10:37 PM   #4
chevy49
chevy49's Avatar
does anyone have a clue?
Old 06-19-2010, 12:57 AM   #5
T Hilde
Sure, box the frame.
T Hilde is offline   Reply With Quote
Old 06-19-2010, 01:15 AM   #6
mr48chev
mr48chev's Avatar
Yes, I have a couple of different friends who have installed a lot of them in cars and trucks between them in the past 30 years.
Most all of the early Cobra kit cars had stock MII crossmembers and suspension. Those crossmembers used to sell for right at 100 bucks across the counter at any Ford Dealers Parts counter but the supply dried up years ago.
Some guys notched the frame rails to fit the crossmember and some notch the crossmember to fit the frame rails.
Check your pm's.
Personally I'm going to run one of the Welder series www.welderseries.com weld it yourself crossmembers. about 225 bucks and then run the stock MII suspension pieces I have stashed away. I picked up a pair of really nice forged caliper brackets to use 11 inch rotors and GM metric caipers with on Ebay for about 50 bucks.
Altogether I should have around 500 in the front end hub to hub minus the rack and pinion when I get it together.
