Old 06-18-2010, 10:58 PM   #1
max71c10
max71c10's Avatar
3" body lift problem
i have a 71 chevy custom 10 wit a 3 speed on the floor with a 3" body lift and the hole in the firewall for the clutch needs to be cut or something so the clutch will be at a more vertical angle. how would i go about doing this because i cant drive my truck with the clutch 2 inches from the floorboard?
max71c10 is offline   Reply With Quote
Old 06-19-2010, 07:46 AM   #2
crawdadfox
crawdadfox's Avatar
Location: New Orleans Louisiana.....a great place to visit but you wouldn't want to live here!!!
Re: 3" body lift problem
If i remember....you need to lengthen your clutch rod about two inches.
Down......with the sickness!!
crawdadfox is offline   Reply With Quote
Old 06-19-2010, 08:55 AM   #3
LONGHAIR
...ah, 3 inches.
This hould have been explained in the directions. You need to cut the vertical portion of the clutch rod in two and weld in a 3" section of rod. It should have come with the kit. The same pice works for either the clutch rod or the shifter linkage in the automatics.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-20-2010, 03:35 AM   #4
max71c10
max71c10's Avatar
i got it to work but i got another problem how should i install the bolts for the back of the cab? i was thinkin impact wrench because they came out today when i turn on an elavated road and i reckon it flexed to the point of the bolt falling out. im also thinking about putting the original ones on and tourquing the hell out of em.
Old 06-20-2010, 08:32 AM   #5
LONGHAIR
OK, I'm confused? How did the bolts "fall out"? They should be tightened into a nut....
How would the original bolts ever fit with 3" lift blocks?
Old 06-20-2010, 10:47 AM   #6
Kayotic
Kayotic's Avatar
Do they tighten into a nut or is it threaded from the bottom to a nut plate in the cab?
Atlanta Craigslist
Hurst Indy Pickup Truck 3-Speed Shifter - 5010016
Kayotic is offline   Reply With Quote
