Old 06-18-2010, 11:30 PM   #1
sweetnlow67
sweetnlow67's Avatar
first build
this is my first build of any kind, not there yet but getting closer please be kind as i have no prior experience with welding body work or suspension lol
sweetnlow67 is offline   Reply With Quote
Old 06-18-2010, 11:32 PM   #2
sweetnlow67
Re: first build
more pics
Old 06-18-2010, 11:36 PM   #3
sweetnlow67
Re: first build
more...
Old 06-18-2010, 11:38 PM   #4
sweetnlow67
Re: first build
still more
Old 06-18-2010, 11:42 PM   #5
sweetnlow67
Re: first build
i found out quickly im going to have to move the bags farther back, im thinking of mouthing them in a different place altogether
Old 06-18-2010, 11:42 PM   #6
sweetnlow67
Re: first build
and the picture of the 4 link bar is my attempt at welding
Old 06-18-2010, 11:43 PM   #7
jmedero
jmedero's Avatar
Re: first build
Sweet. What are your susp set up specs?
68 BB burb build thread Scott's super slam front/rear
http://67-72chevytrucks.com/vboard/s...d.php?t=378084
jmedero is offline   Reply With Quote
Old 06-19-2010, 01:16 AM   #8
FnLow69
FnLow69's Avatar
Re: first build
looks good man, nice and low... On your welds i'd say turn the heat up and slow down just a little. You want nice dimes over lapping. You can even do a "C" pattern or weave back and forth. keep up the good work.
I see two different wheels in the pics which ones you going to use?
Justin
FnLow69 is offline   Reply With Quote
Old 06-19-2010, 09:30 AM   #9
gixxerpymp
Re: first build
Awesome work man. Keep us updated!
gixxerpymp is offline   Reply With Quote
Old 06-19-2010, 10:39 AM   #10
gringoloco
A guy with a truck
gringoloco's Avatar
Re: first build
Very ambitious for having no experience. Looks good- I've seen some less than stellar first attempts on this forum- yours is not one of them. As mentioned, more heat in your welds, especially on the thick pieces like you're working with. Have you thought about doing a sleeve style mounting off the back of the axle? Definitely wanna move the bags back though, if you plan on keeping them on the links- if you calculated the leverge on them, you're likely close to exceeding their limits. Again, looks really good...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-19-2010, 11:17 AM   #11
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: first build
lookin awesome im in!
John
1999 Toyota Tacoma 4x4
Old 06-19-2010, 01:39 PM   #12
67cheby
67cheby
67cheby's Avatar
Re: first build
nice progress
67cheby is offline   Reply With Quote
Old 06-19-2010, 07:03 PM   #13
kev2809
low n' slo
kev2809's Avatar
Re: first build
good progress, its gonna look good! whats the front setup?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 07-30-2010, 12:25 AM   #14
gixxerpymp
Re: first build
Any updates?
Old 07-30-2010, 02:34 AM   #15
OARNGESI
OARNGESI's Avatar
Re: first build
Nicew work so far
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 07-30-2010, 11:47 AM   #16
greystoke
Re: first build
looks great, did you use a cutoff wheel on the bed?
"Fear makes the wolf look bigger"
http://67-72chevytrucks.com/vboard/s...d.php?t=305629
greystoke is offline   Reply With Quote
Old 07-30-2010, 06:09 PM   #17
maxxxy
maxxxy's Avatar
Re: first build
very nice project. is your support with the wishbone mount, does it go through the frame?
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 07-31-2010, 11:55 AM   #18
sweetnlow67
Re: first build
i did use a cutoff wheel for the bed, with the right measurements it was pretty easy i just took my time, and no the support doesn't go through the frame, but it sounds like that would have been a good idea. no updates yet, hoping to get some more work done on it in the next couple weeks
