Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Did a search and found a thread where a guy swapped suspension from a
2wd to a 4wd. However, I am getting a crew cab from a member here and will be doing a 4x4 swap on it. I was hoping to find someone who has done this who has a few good pics as well as any advice they can offer. Thanks in advance guys.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
Location: Where I come from, it's cornbread and chicken...
Re: 4x4 conversion
I think b454rat has or is doing the conversion.
Re: 4x4 conversion
I'm doing one. Check out the link to some pics in my sig. The wife knows about it now, so will be bringing it home soon, so I can get better pics if yah need....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
#4 | |
Still plays with trucks
Re: 4x4 conversion
1/2-ton or 3/4-ton conversion or try to keep it a 1-ton when it becomes a 4x4? Are you going to keep it a long bed or cut it down to a short bed?
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
Re: 4x4 conversion
DIY B52 kit and shackle flip!!!
Re: 4x4 conversion
Cool Josh! Glad you finally found one. I know you have been looking for a while. Let me know if you need some help.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
Re: 4x4 conversion
Will do Jeramy, thanks. It is a 3/4 ton truck but I will most likely be swapping in a Dana 60 front and leaving the 14FF in there as well. It has already been shortened so it will be CCSB 4x4! I dont have a donor truck but there are a few 4x4 Suburbans in the salvage yard I can get hangers and stuff from if needed. I saw the B52 kit to use the GM 52" rear springs up front to get 4" lift and that looks like a good idea too. Should ride good with the 52s up front. Need to find a 4x4 engine crossmember too though.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. Last edited by STOCKISH; 06-19-2010 at 01:35 PM. |
Re: 4x4 conversion
That buddy of mine I was telling you about has a friend that has a D44 front. He's gonna find out the gears in it and how many lugs and get back to me.
Re: 4x4 conversion
Cool, LMK. Hopefully it's a 8 lug 44HD. 4.10 gear too!
Re: 4x4 conversion
I have a spare 4x4 front crossmember and front frame section for that matter from my 84 K5 parts truck but it would cost you more to ship it 3000 miles than they are worth.
Re: 4x4 conversion
The 4wd crossmember won't work, not without modifying it. I tried 2, one from a 1 ton, and another from a 1/2-3/4 ton. After looking at the 2, they are the same thing. IIRC, 1/4" needs to be trimmed so it will fit in the frame rail.
I got a crossmember from Tennessee Diesel conversions, hopefully someday I'll drop a Cummins in the truck. Now I just want the stupid thing to run on it's own....
Re: 4x4 conversion
Will it not work if trimmed to fit or does that move the engine mount locations too far if cut down to fit?
#13 |
Re: 4x4 conversion
Front to back is fine, but it won't fit inside the frame rails without trimming it. I'm sure if you have a plasma or torches you could make it work, this wasn't an option for me, I didn't have any of this stuff at the time I was putting the truck together. I think it's only a 1/4" if that, this was last summer, I can barely remember what I did yesterday.....
#14 | |
Re: 4x4 conversion
A 1/4" you could easily make up in the body mounts. Separate the front cross brace from the frame then spread it out the 1/4" to get the engine crossmember to fit then reinstall the front cross brace. The worst thing you might have to do is slot the frame mounts for the core support body bushings a little on each side to get them to line up.
#15 |
Re: 4x4 conversion
It wasn't the width is was the inside height of the frame, would not go in in less trimmed the crossmember.
#16 |
Enthusiast
Re: 4x4 conversion
Not tryin to do any thread jacking but i was readin this and i just coudlnt help but think "Well sh*t what's the difference between a C30 and a K20 frame?" I know there are suspension differences but if there aint many differences (if any) then im a happy camper..Well let's be more specific. Camper Special C30 vs a regular old K20
- Cole 1979 Chevy C30 w/ carb 454. 1992 Chevy K1500 w/ tbi 350. *Sold* 1997 Dodge Ram 1500 w/ Magnum 360 *Sold* "Good judgment comes from experience. Experience comes from poor judgment." - George Washington |
#17 |
Re: 4x4 conversion
1 tons have a taller frame than 1/2 and 3/4 ton, couple other differences that I know of. 1/2 and 3/4 have the same spring hangers front and rear on the rear springs, using these gives 42.5" perchs on the axle. 1 ton have "thinner" ones (sits closer to the frame) making 40.5" perch width. The front stuff is the same, hangers and shackles, springs probly beefier as well.
2wd and 4wd have different hangers. 4wd's are taller, where some of the height comes in, springs make up the rest of any height differences. Obviously the front suspension is different.
#18 |
Enthusiast
Re: 4x4 conversion
Ok, i was wondering because around my area, K30s are a hard find, and i wanted to just swap bodys over so im concidering putting it on a K20 (a far easier find) and putting in stronger axles to attempt to keep the tow capabalities
- Cole 1979 Chevy C30 w/ carb 454. 1992 Chevy K1500 w/ tbi 350. *Sold* 1997 Dodge Ram 1500 w/ Magnum 360 *Sold* "Good judgment comes from experience. Experience comes from poor judgment." - George Washington Last edited by Fixwhataintbroke; 06-20-2010 at 10:44 PM. |
#19 |
Re: 4x4 conversion
c20 and c30 crewcab frames are identical according to the GM frame spec chart
#20 |
Re: 4x4 conversion
Dunno why GM did that, still a 1 ton, but called it a 3/4 ton. Maybe it had one less spring in the back, wasn't quite a 1 ton, so call it a 3/4 ton?? Or maybe a 7/8 ton??
#21 |
Re: 4x4 conversion
lol don't know, but there was a thread a while back and it was found out in that thread that the crewcab 3/4 and 1 ton frames were the exact same specs...maybe they did that just for simplicity...there was no 1/2 ton crewcab so maybe it was just easier to manufacture one frame and not two...but I thought the same thing about the weight rating...the one that Josh is getting from me that he's talking about converting in this thread, is a 3/4 ton 2wd, but it has a 14 FF in the rear end, a 1 ton axle...I also don't think they made a 1 ton crew that wasn't a dually...so all the crewcab duallys are 1 tons and the fleetside beds are all 3/4 ton...I assume
#22 | |
![]() Quote:
I found a rolling frame for $100 and it was the best money spent on the project so far. I was able to cut the donor frame just in front of the cab and bolt it up next to my frame. This gave me a full template to measure from and perfect location for all the holes I needed in my frame to bolt the K-Member up. You will have less drilling to do but still some. I found the front cross member had to be changed. It supports the sway bar and has brackets riveted to it as well as bolted to it and the frame. The mounts for the core are not the same and require a much beefed up part for the front spring hangers on the 4WD. You will need the rear hanger also and it requires a hole in the frame for it to fit through. You will need a bunch of various brackets from the donor frame, most of them are riveted on and have to be cut off and bolted back to your frame with grade 8 bolts. I found cutting the rivets works well if you first use a cutoff wheel about 1/2 of the way through and then an air chisel to pop the heads off. Then the air hammer to push out the rivet body. In some places you will need to trim the top and or bottom of the frame rails a bit for clearance and you may need to weld on a little in a few places so you have enough meet to bolt through. You will need a cross member for the transmission and transfer case and the extra supports for the ends of the cross member as well as the bracket for the transfer case to frame torque control. The list goes on and on. I figure I got about $800-$900 worth of stuff off that donor frame. All of these things I found out as I went along in the project and did not expect when I first started the conversion. It is not hard to do but it is time consuming. If you can find a donor that perhaps has accident damage grab it and you will be amazed at what you need from a donor frame. As for the over all dimension of the frames they are the same according to the book I have and so far I have not found any deviation in that category. Good Luch and keep us posted on how it goes.
07 Chev 2500HD Classic Project Ranch Hand, Hauling A$$ since 1973 ![]() I was told this Project had a L-72 427 425HP, It did not. It does have a 427 block and parts from various 427 motors. It will end up with a nice strong 454 in the end. It has not been run for 20+ years Frame up restoration started2/15/2010 ![]() |
#23 |
Re: 4x4 conversion
I'd love to turn my truck into a 4x4
#24 |
Re: 4x4 conversion
Josh,
I have the front clip off my K5 currently and have only removed one motor mount. I know its half ton stuff, but if you need any pics of the 4x stuff let me know. It is all hanging out in the open and easy to get pics of. I would offer you the stuff I'm taking off mine, but I dont know when I'm going to get around to removing it all. Unless you want to come help one weekend! ![]()
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
#25 |
Re: 4x4 conversion
Since this frame was already cut to make a CCSB I was thinking about taking a K30 and cutting the frame just behind the front cab mount and the same on the CCSB and swapping the front frame sections. I have alot of fab experience and a buddy who welds for a living so this does not worry me too much but just hate to have too many splices in the frame I will be driving every day. What are your guys opinions on that?
