06-19-2010, 01:32 PM | #1 |
Junior Member
Won't start!
It has been a while since this has been discussed and I know that a lot of you are very knowledgeable, but for new people to the 67-72 world I will share what just happened recently.
I had been having problems over the last year or so with my truck not turning over, usually at the worse times. Normally I would twist the cables and it would start, then after I got it home I would clean both the cable ends and the battery posts and there would not be a problem again for a while. This time it happened when I got in it to come home and there was a rain storm going on. When it stopped raining I wiggled the cables and it fired right up. When I got home I was determined to figure out what was wrong. I cleaned the cable ends, battery posts and grounds, then I figured I might as well go one step further. I cut a small part of the insulation off of the positive cable by the battery end, yep you guessed it. The wire was very corroded inside the insulation. I replaced both battery cables and now there should not be a problem for a very long time. It turns over better than it has. Danny P.S. Sorry for the long post.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
06-19-2010, 02:53 PM | #2 |
Re: Won't start!
Smear a little grease or vaseline over the posts and end of the cables too. Stops corrosion.
06-19-2010, 08:08 PM | #3 |
Grandpa in the rustmobile...
Re: Won't start!
yeah grease a lil bit on the connections make sure everythings tight good luck
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
06-19-2010, 09:16 PM | #4 |
Your UncleBen
Re: Won't start!
Hahah As I was reading I was thinking man just replace those cables and end your grief! And then you did.... GOOD JOB! Glad it fixed your problem!
lata CHRIS
68 C10 shortbed -- Street/Strip |
06-19-2010, 09:21 PM | #5 |
Junior Member
Re: Won't start!
I was kind of long winded, huh? I guess I was an instructor too long, lol.
06-19-2010, 09:49 PM | #6 | |
Your UncleBen
Re: Won't start!
lata CHRIS
