Old 06-19-2010, 01:52 PM   #1
big mike71
big mike71's Avatar
Wheel spacers and longer studs
I want to lower my truck, But to do it I will need a 1/2" spacer on the rear. My question is in order to put in longer studs do you have to pull the axle? Thanks.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 06-19-2010, 02:52 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: Wheel spacers and longer studs
Mike, you shouldn't have too, but that will depend on how long the new studs actually are.
I needed to have longer studs on the rear with my new wheels and I was able to remove the drum, knock out the old ones with a BFH, and then "draw" in the new longer studs with a socket, and a stack of washers. You might have to turn the axle to get the right spot to fit the new studs in but overall as long as they are not excessively longer, you should be ok.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 06-19-2010, 03:42 PM   #3
raycow
There is enough room to install the studs without pulling the shafts, but it's not the best idea to hammer them out. The hammer blows get transferred to the spider pin and ultimately to the differential bearings. A tool is made specifically for this purpose
http://www.denlorstools.com/home/dt1...auto_tool.html
but it is hard to justify the cost for a one-time job. You might want to see if a tool rental outfit has one.
Having said all this, I have hammered them myself and haven't destroyed any rear ends.....yet.
Ray
raycow is offline   Reply With Quote
Old 06-19-2010, 05:07 PM   #4
big mike71
big mike71's Avatar
Old 06-19-2010, 11:34 PM   #5
ERASER5
ERASER5's Avatar
Yea! A new use for my ball joint/hub C-press! Woot!
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 06-20-2010, 08:44 AM   #6
68_chop_top
68_chop_top's Avatar
The 3/4" wheel spacers I used came with studs and holes and nuts for the original studs. Their studs where in-between my studs. Just put the ring (spacer) on like your wheel and use their flat nuts to tighten spacer to the wheel hub. The spacer's studs where then used to mount my wheels using my lug nuts. Hope this makes sense. I ordered 5 on 5" to a 5 on 5" with 3/4" width. It was called a wheel adaptor.
Mine is chopped, has a clutch, and a big block.
68_chop_top is offline   Reply With Quote
Old 06-20-2010, 09:39 AM   #7
7T2
Active Member
7T2's Avatar
For the money that adapters cost it's almost worth it to avoid the work. The way you are describing, you would have to buy new studs and the spacers, then do all the work to swap them out. When you're done you have a setup that probably isn't as durable as your original.
You can get a set of two billet aluminum spacers all over the net for $90 that will do exactly what you want to do, and they are engineered to give you the same durability as the stock setup. You can get them in the same bolt pattern, or you can get them as adapters to change the bolt pattern.
http://adaptitusa.com/
1957 GMC Ambulance
1962 Belair Wagon
1963 C80 Truck Cab *FOR SALE*
1969 Chevy C10 Short Bed
1972 Chevy C10 Long Bed *SOLD*
1996 C3500 Dually *SOLD*
7T2 is offline   Reply With Quote
Old 06-20-2010, 01:29 PM   #8
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
I was just thinking ball joint press/C-clamp as I was reading this post.
As far as the strength of adapters vs spacers it seems to me that if you use a spacer then the wheel is still connected directly to the axle so if the spacer were to crack the wheel would still be attached. But if you had an adapter crack then the wheel could come off. I know it's a long shot that either would happen, but I'm just sayin...
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 06-20-2010, 01:42 PM   #9
ERASER5
ERASER5's Avatar
Not 3/4" thick spacers. 1'+ yes, 3/4" No. The 3/4" spacer makes up for the narrow rear when you put disc brakes on the front. I have yet to find 1 piece 3/4" spacers or adapters.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
Old 06-20-2010, 04:15 PM   #10
7T2
Active Member
7T2's Avatar
Ah, I missed that. You're right, those billet adapters start at 1" thick. Don't know what I was thinking.
1957 GMC Ambulance
1962 Belair Wagon
Old 06-20-2010, 04:48 PM   #11
big mike71
big mike71's Avatar
I don't know if I want come out an inch. I'm going to have to do some measurements.
Old 06-20-2010, 08:19 PM   #12
ERASER5
ERASER5's Avatar
Actually, they start at 1.3" which is quite a lot X2.
'70 GMC C1500 LWB
Posi 6 Lug Dana 60
