06-19-2010, 04:35 PM | #1 |
Hmmmm...will it bolt up to a 205 case? LOL
06-19-2010, 09:10 PM | #2 |
Re: Hmmmm...will it bolt up to a 205 case? LOL
Wow that is a good deal for a P-pump cummins....
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
06-25-2010, 02:18 AM | #3 |
Enjoying left field
The easiest thing to do would be to go with a divorced 205. They're pretty plentiful.
06-25-2010, 06:22 PM | #4 |
thats cheap as hell that would go for 3-4k over in my hood. too bad its 3,000 miles away.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
06-27-2010, 11:33 PM | #5 |
I whould bet somthing is wrong with that 6BT. Nobody in their right mind whould go through the hassle of changing the engine for 35 horsepower. You can buy fuel plates to up-rate the engine. Examble http://www.tstproducts.com/94-98dodg...thvideo-1.aspx
In the pic of the engine it had a orange oil filter on it, That chould mean a Baldwin or a Fram filter. Fram filters are notorious for coming apart & clogging the piston cooling nozzles. The Allison 542/545s do not have a "park" so the trans mounted parking brake will need to be retained. |
