06-19-2010, 08:13 PM | #1 |
The vague nature of my truck is pissing me off...
I would like to toss a 4 inch lift on my 1970 GMC 1500, SO I start poking around under it and notice some things which seem odd....
1. Keep in mind the truck has no suspension lift kit now. It is sitting on 31's and they fit like they are stock. 2. It has 4 inch blocks between the axle and leaf springs(6 leaf packs) in the rear. I don't THINK the factory built them like this, but anything is possible. 3. The front springs are a real puzzler. They look like your standard 2 leaf half ton negative arch springs, until you look twice at the driver's side. It has a THIRD leaf which is only about a foot long! Was that a factory deal or has someone monkeyed with the suspension long before I got the truck? pic of the rear set up: Keep in mind, this shot was taken with about a cord of oak firewood in the bed, so it is well compressed. Sooooo... any ideas on this puzzler? |
06-19-2010, 08:30 PM | #2 |
Re: The vague nature of my truck is pissing me off...
i would guess it already has a lift and the height of the block is the height of the lift.
1995 GMC 4x4 1/2 ton 1999 Jeep Wrangler w/ 33's 68 camaro 350/350 1987 Chevy 3/4 ton 4x4 Suzuki DRZ 400s Dual Sport 1971 chevy long bed 2x4 194? Dodge 2.5 ton 1980 Chevy Cheyenne 4x4 1/2 ton I6/sm455 1989 Chevy V30 crewcab dually 454/TH400 |
06-19-2010, 09:38 PM | #3 | |
If that were the case, it came with 26 inch tires as OEM and looked like a tail dragger low rider. This is it on 31's unloaded: loaded with wood: loaded with car!: I doubt it has a kit already(in the standard sense) because there is only about 3 inches travel to the bump stops when sitting level a the front axle and the springs have a negative arch. |
06-19-2010, 10:06 PM | #4 |
any pics of the front springs? Looks like stock height to me...
Here are the rear springs from my 1968 1/2 ton, the third leaf was added for 1/5" of lift...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 06-19-2010 at 10:11 PM. |
06-20-2010, 12:12 AM | #5 |
I'll have to crawl under there with my phone tomorrow to pop some pics. I am wondering if maybe someone swapped some 3/4ton 2wd springs in the back and lifted it with the 4 inch block to level it.
This leads me to my next though on lifting it... If I bought a set of 4 inch springs for the front, I could just do a shackle flip on the back. |
06-20-2010, 01:09 AM | #6 |
Look at the shackles in the rear of the front springs. A cheap lift is blocks in the back and shackles in front. A stock shackle is about 4" center to center.
Look at the rear leaves. Notice that some at least aren't tapered, and some are about the same length. It looks like someone has added a couple leaves in back. I'm not sure what your question is... You know you have a lift since its got blocks in the back. It sits level so its got to be lifted in front. It sits higher than stock. It probably rides like there's no rear suspension because of the extra leaves... On mine each leaf is about 6" shorter than the one above it, or 3" on each end. Nice looking truck BTW. |
06-20-2010, 09:05 AM | #7 |
I think that someone replaced the rear springs at some point. Almost looks like they used 3/4 ton front springs on the rear... How does it ride?
If you haul heavy items (like wood) then the rear shackle flip would work with new front springs, Or just replace all four springs with K-20 4" lifted springs...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
06-20-2010, 11:06 AM | #8 | |
You mean they might have taken leaves from a 3/4 ton front pack and added them to the stock rear pack? I suppose it is possible. This truck has parts of several trucks in it. The tailgate was hugger orange and has higher level trim, the doors are from a 72(vent wing screw holes), the inside is 100% LMC, The manifolds have Corvette casting numbers, the heads appear to be big valve small chamber according to the casting on the end, and the front axle has a disc brake swap. With all the farm land that this county was until the 90's who knows what kind of cobbled up machine someone put together to keep things working! Oh yeah...the steering box is from a 75..... Last edited by Davetopay; 06-20-2010 at 11:07 AM. |
06-20-2010, 02:15 PM | #9 |
do the rear springs have any arch while the bed is empty? Front leaves are flat, rears are usually arched.... that's why I guessed that.
06-20-2010, 03:28 PM | #10 | |
I am wondering if maybe someone took a set of 3/4 ton rear springs from a 4x2 and used blocks to level it. |
06-20-2010, 03:42 PM | #11 |
does it have stock rear shackles?
There is also the fact that nobody aver really knows what GM did back then. GMC also seems to have quirks in parts... could be totally stock... hard to tell.
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" Last edited by msgross; 06-20-2010 at 03:43 PM. |
06-20-2010, 04:16 PM | #12 | |
Yup. SHackles look as stock as they can be, and the hangers are still attached with rivets. Like I said...it's a bit of a puzzler. |
06-20-2010, 05:19 PM | #13 |
Kid's Mechanic
I think thats an extra challenge when working on older trucks,I have replaced 1/2 with 3/4 springs on two trucks in the past.
06-20-2010, 10:25 PM | #14 |
Active Member
You say it is a combination of vehicles; are the front axle hangers riveted also? On my 68 converted to 4x4 with the 4x2 frame, I had to put a 4" block in the rear to match the stock height 4x4 front springs to sit level.
Just a thought Good luck...... Max
Never try to teach a pig to sing; it wastes your time and annoys the pig! Gets More Chicks My lugnuts require more torque than your honda makes! 68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4". |
06-21-2010, 07:31 AM | #15 | |
As far as I can tell, the chassis is NOT a conversion. The front suspension is riveted like factory. It still has the driver's side "capture" at the front hanger and the passenger's side limiter behind the shackle. Not to mention the original mounting of the crossmember for the NP205. Also, the VIN on the frame matches the cab. I guess what it comes down to, if I want to put a mild lift on it, is I will have to shell some coin out. I have this gut feeling that if I buy a kit iff the shelf, something won't be right. |
06-21-2010, 12:42 PM | #16 |
SWB 4x4 Collector
I am with MSGROSS, on the topic. It looks like there are front springs in the back. All stock rear leafs and lifted leafs will have an arch to them. It appears that they had to use 4" lift blocks to level everything back up. I think it's just a matter of pulling the leafs out and installing a new set, or getting you some stock rears and a 4" spring set for the front. I also agree that if you haul stuff, a shackle flip would be the best possible decision if you are wanting to lift it. Trevor
TREVOR 1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks) 1972 Jimmy (soon to be Hickey cloned) 1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track) 1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank 1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT) http://67-72chevytrucks.com/vboard/s...d.php?t=624819 1989 V3500 Crew Cab (454tbi, NV4500, np205) 1970 Chevelle SS (LS5 454,th400,8track,buckets,tach) :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
