06-20-2010, 01:25 AM | #1 |
Oil & Coolant
Gonna flush my radiator and change my oil tomorrow. What's recommended? It's a 350ci with 150,000 miles. I was thinking 10W-30 maybe a synthetic? Idk I don't want to find some "new" leaks, but I'm sure it'd be good for the motor. Also how many quarts of oil? Coolant, I have no idea, pre-diluted? concentrate?
Thanks Yall, I know these are simple questions but I think they're pretty important.
'68 C10 LWB 6.2NA/NP833 3.73's |
06-20-2010, 03:46 AM | #2 |
Big Red - Now its a SWB!
Re: Oil & Coolant
most of the stock oil pans are 4 quart + 1 for the filter = 5 total quarts for a oil and filter change.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
06-20-2010, 07:36 AM | #3 |
its all about the +6 inches
Re: Oil & Coolant
i wouldn't bother with synthetic on an engine of this era with that many miles. Just pick a name brand high quality oil and get some zink additive from your dealer to help save your camshaft. Any filter will get you by, fram being less than craptastic, and wix/napa gold being at the top of the pile (as far as normal budget friendly filters go).
5 quarts is the norm as mentioned before... a quart or two under the seat (still in the bottles) is a good idea. On coolant, I have a hard time convincing myself that a premixed coolant is a good idea... however, it is getting harder and harder to find straight coolant these days. Stick with a traditional green coolant. If your coolant right now is green, then I'd just drain and fill. If it is brown, or if you have white crap building up on the inside, in the tubes of the rad, then a good flush with prestone super flush (best one on the market today) and then fill, and you're done. |
06-20-2010, 08:36 AM | #4 |
Old School
Re: Oil & Coolant
Rotella T is a good oil that still has zinc in it. The zinc is needed to keep flat tappet lifters alive. It is what I use on all my vehicles that don't have catalytic converters.
#1 Project...69 Chevy swb Fleetside (Dad's truck) #2...1983 El Camino SS (Choo Choo Custom) #3...1974 Datsun truck (4.3L V6/4L60E) #4...1951 Cadillac Limo (1975 Caddy running gear) #5...1938 Dodge M38 3/4 ton Military truck #6...1968 Sportster XLCH trail bike 5 GMC & Chevy parts trucks 68 to 72 Last but not least; My 1978 Harley Davidson Electraglide (trusted & reliable companion for the last 30 years) |
06-20-2010, 09:13 AM | #5 | |
Your UncleBen
Re: Oil & Coolant
lata CHRIS
68 C10 shortbed -- Street/Strip |
06-20-2010, 09:17 AM | #6 |
Active Member
Re: Oil & Coolant
FYI - Rotella no longer carries zinc - they were one of the last to carry it but diesels had to meet some of the same standards regarding oil - time to update the choices
For a high mileage oil I like the Pennzoil high mileage oil seems to work better than regular oil - slows down any smoke issue I am a wix/napa gold oil filter fan - cheap insurance in my book
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles 18.5" x 31" Hoosier Pro Street Radials ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree |
06-20-2010, 10:00 AM | #7 |
406 Powered
Re: Oil & Coolant
It still has zinc in it for now. I sell it in my 6 stores.
70 GMC 68 c10 2002 silverado 72 4x4 |
06-20-2010, 10:03 AM | #8 | |
406 Powered
Re: Oil & Coolant
06-20-2010, 10:22 AM | #9 |
20' Daredevil (Ret)
Re: Oil & Coolant
I've always used 2 gallons straight Prestone and fill the rest of the way with water for a rough 50/50 mix. Pre-mixed may be handy, but you pay nearly as much for product that is 50% water. Great profit for Prestone....
06-20-2010, 10:39 AM | #10 |
Active Member
Re: Oil & Coolant
BAdpurple - while the fact that you can special order Rotella mixed with the old formula it sounds like the exception and not the rule - kind of like playing Russian roulette with your motor.
I play it safe and use Lubriplate GPO motor oil (they advertise they have enough zinc) but to be safe i still run 1/2 bottle of EOS with every oil change. I sleep better at night that way
06-20-2010, 11:52 AM | #11 |
Re: Oil & Coolant
most of the 'over the counter' rotella has LESS zink than the typical gasoline oils.
You can run that in yours, but I refuse to run it in mine. |
06-20-2010, 02:47 PM | #12 |
Your UncleBen
Re: Oil & Coolant
Are the any distinguishing markings on the Rotella bottle let us know which is which? I wouldnt mind running it if i KNEW what it was.... Until then just more GM EOS At least until my new hydraulic roller motor is done! Then wont have to worry so much anymore!
lata CHRIS
06-20-2010, 03:40 PM | #13 | ||
"I ain't nobody, dork."
Re: Oil & Coolant
I've been using Pennzoil 30wt or 10w30wt since the 70's in everything I have ever driven (excluding diesels) and Wix filters. Nowadays I add the ZDDP additive in the same oil. Never had a prob... just make sure to use the additive for your flat tappet camshafts.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
06-20-2010, 03:46 PM | #14 | |
406 Powered
Re: Oil & Coolant
70 GMC 68 c10 2002 silverado 72 4x4 Last edited by BADPURPLE70CHEVY; 06-20-2010 at 03:48 PM. Reason: spelling |
06-20-2010, 05:11 PM | #15 | |
Your UncleBen
Re: Oil & Coolant
lata CHRIS
06-20-2010, 05:24 PM | #16 |
Re: Oil & Coolant
Valvoline Racing oils still contain ZDDP.
06-20-2010, 05:47 PM | #17 |
Active Member
Re: Oil & Coolant
Yes valvoline racing oils do contain zinc - BUT - they do not have detergents designed for longer term street driving
The race oils are designed to be changed frequently.
06-20-2010, 05:50 PM | #18 |
Your UncleBen
Re: Oil & Coolant
I have 2 cases of this for my flat tappet 383 in my Malibu that I bought a whileeeee back..... Hope to sell the motor/trans before I use up all the oil! I heard they dont have the zinc anymore either...Who knows anymore...
lata CHRIS
06-20-2010, 06:01 PM | #19 |
Between Trucks...
Re: Oil & Coolant
I just add ZDDPlus to my oil and don't worry about it.
Beat it to fit, Paint it to match... |
06-21-2010, 08:01 AM | #20 |
Re: Oil & Coolant
don't blame the EPA on the lack of zink... blame the auto makers who got sick of replacing catilitic converters pro bono. They are the ones who convinced the feds to drop the zink content, and they had been trying for 15+ years to do it. The feds were actually in OUR corner on that one.
07-20-2010, 10:38 PM | #21 |
Re: Oil & Coolant
the rotella that still has the zink has a flower looking thing on the back of the bottle it has three points a red leaf blue and a yellow its hard to explain it but once you see it you will know and i only use ac delco oil filters PT# PF 1218
Greater love hath no man than to lay down his life for a friend. Members i Have met Earl Slick68 1969 Stepside Build thread http://67-72chevytrucks.com/vboard/s...=1#post4253546 Chevy Trucks the longest lasting most dependable trucks on the road |
07-20-2010, 10:39 PM | #22 |
Re: Oil & Coolant
yeah valvoline 20w-50 racing still has ziink as well
07-20-2010, 10:52 PM | #23 |
Re: Oil & Coolant
ok i guess that is why i am having to replace my cam and lifters soon. havent heard anything on the zinc thing. havent been paying attention. been putting in the same old oil that i always put in and never looked twice. VAL 10W 40 so what is it that the zinc does. and where do i get this stuff
Mark 1968 C-10 SWB 307/munci 4spd/411possi 1986-1990 1972 Cheyenne-10 LWB 350/TH350 IF SHE WHOULD HAVE KEEPT THE SHIRT ON THEY WOULDNT HAVE BROKEN UP THANKS ADAM SANDLER U. S. Navy Seabee "CAN DO", "The difficult we do at once. The impossible may take a little bit longer.","We Build We Fight", "Work Hard Play Hard" |
07-21-2010, 12:08 PM | #24 |
Re: Oil & Coolant
^^^ = http://www.zddplus.com/
07-21-2010, 01:02 PM | #25 | |
Re: Oil & Coolant
The ONLY way to get the right mix of 50-50 into your coolant system is to: 1. Flush with fresh water then drain it. 2. Consult your owner's manual to determine the capacity of the system. 3. Fill 1/2 of the capacity with straight (not pre-mixed) anti-freeze. 4. Top off with straight water. Anything else won't get you the 50/50 you need to keep your block from freezing and cracking in cold weather. There is NO way to drain all the water out of your block with the engine installed in the vehicle. Because of that basic fact you need to follow the above steps to insure the correct protection of your engine. In the absence of documentation of your capacity, start with 2 gallons of straight like Stocker does. Most small block Chevrolet systems are on the order of 16 quarts. If you're still worried purchase one of those anti-freeze testers and make sure it tests to -40 or better when you're done.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
