Old 06-20-2010, 11:56 AM   #1
jlaird
jlaird's Avatar
Switch questions
Is a toggle switch that will fill and dump one bag called a DPDT? How many prongs does it have?
Suicide doors have switches that have 3, 6, and 12 prongs. What do each of those do?
I'm seeing SPDT ON/OFF/ON momentary switches on ebay. So I'm confused as to what type of switch will fill and dump a single bag.
I'm leaning towards five switches: fill and dump for each corner and one switch to fill/dump all four at once.
Thanks for the help.
josh
jlaird is offline   Reply With Quote
Old 06-20-2010, 12:44 PM   #2
fixit-p
fixit-p's Avatar
Re: Switch questions
You need 4 of a SPDT (3 prongs) and 1 of a 4PDT ( 12 prongs) switches, each pole represents one corner the center prongs are all power and the outer prongs go to the valves one side to the fill and the other to the dumps
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 06-20-2010, 01:23 PM   #3
gixxerpymp
Can't you just run it with 1 switch for the front and 1 switch for the back? Then a manual on/off switch for the compressor?
gixxerpymp is offline   Reply With Quote
Old 06-20-2010, 01:25 PM   #4
jlaird
jlaird's Avatar
Ok, so a DPDT would be 6 prongs and would control two bags at once like if I wanted to dump/fill the front or rear?
Old 06-20-2010, 01:27 PM   #5
jlaird
jlaird's Avatar
I would actually prefer this but what happens if one corner need more air than another?
Old 06-20-2010, 03:26 PM   #6
fixit-p
fixit-p's Avatar
Correct DPDT would have 6 prongs and would act similar to controling the front or rear with 1 SPDT (3 prongs) toggle but would still leave both sides electrically isolated when the switch isn't actuated.
Old 06-21-2010, 07:20 PM   #7
gixxerpymp
I'd like to know this also.
I want to run the least amount of switches.
Old 06-21-2010, 07:39 PM   #8
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
ok here goes and the could get complicatied but I'll try to make sence
DP/DT= double pole/double throw....this means that its acually 2 switches in one and it will work in the up and down postion (the center is your power the top and botom have power whne the switch is hit) heres the goofy part when the switch is in the up postion it feeds power from the middle to the BOTTOM of the switch and vise versa..(6 connectors)
SP/DT= Single pole Double throw...single pole is just one switch with the same Double throw ( 3 connectors)
ok part 3:
yes you can run 2 DP/DT switchs to your bags ( one DP/DT for the front and one for the rear) BUT if the ruck is loaded heavy to one side it wont lift even...my truck is set up like this BUT I also have 5 switchs in my glove box 1 shuts off the compressor the other four are SP/DT which allows me to tune if needed....I havn't had o use them YET but its an option I added and the wiring can be kinda confusing if your new to it...
One thing I found by accedent is that if you use the flat four trailer wire it works very well to wire up your valves...use one flat four for the front valves and one for the rear valves...it makes it easy to wire easy to trace the wires and getting them tucked away is easy also
hope that helps
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 06-22-2010, 01:25 PM   #9
smbrouss70
smbrouss70's Avatar
If you want 5 switches, why not get one of these?
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWNX%3AIT
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 06-22-2010, 01:57 PM   #10
Hottrucks
Hottrucks's Avatar
That is killer and would save a TON of work and how can you say No for 20 bucks...I would have ditached the box and mounted the top into my console
Old 06-22-2010, 03:28 PM   #11
gixxerpymp
I thought about that but I would think it would be annoying to have to hold it.
Old 06-22-2010, 03:44 PM   #12
smbrouss70
smbrouss70's Avatar
I thought the same thing, but I bought one anyway. My truck isn't road-ready yet, so it may be a pain, but it's only temporary until I can afford the AccuAir set-up that I want.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 06-22-2010, 07:36 PM   #13
kev2809
low n' slo
kev2809's Avatar
35 with shipping. thats the one im using, its small but it works pretty good. the only thing i wish it had was 2 more switches for all front up/down and all back up/down
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
