![]() Join Date: Jul 2000
Trim removal tricks
It's been many years since I've done it, so can't remember how to remove the horizontal trim below the cab rear window.
And while I'm at it, same goes for the upper and lower trim pieces on a fleetside tailgate.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
Re: Trim removal tricks
the ones in the tailgate are clips im not sure about those but if u just pry on the ones softly they pop right out.. thats what i did on mine.. didnt even damage them
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
The cab trim is joined by a piece in the middle which needs to slide one side or the other. I think the hold downs are plastic and will need to slide to unlock. Something thin behind the trim should let you find the edges of the clip and the stud. Slide the edge farthest away from the stud toward the stud. My disclaimer is you might scratch the paint or break 40 year old plastic.
Someone correct me if I'm wrong please. |
A good ol' flathead screwdriver.
70 Chevy C10, LT1, T5, "Blue Beast" |
