MOTORHEAD!
Gauges!!!!
I'm thinking about replacing the factory gauges in my 69 GMC with something with ACCURACY!! Is there something available the fits in place of the stock gauges??? If anyone has pics of their setup, please post them and the details of what brand you used!!
Thanks! 69GMC910
82 GMC High Sierra VortecPro 496 12 Bolt, 3.42's AFR 265 Holley 850 Performer RPM Air Gap Hooker 2455's TCI Turbo 400 Super Street Fighter TRRC 12 Bolt Eaton Posi Mark Williams Axles Cal-Tracs Hoosier 30x10.5 Radial Slick Full weight long box pickup Current best- 11.33@117mph |
MOTORHEAD!
Re: Gauges!!!!
Are factory tachs available that go higher than 5000rpm? Can factory tachs be re-calibrated to go to..... say 10,000rpm?
Re: Gauges!!!!
Here's a crappy cell phone pic of what I did. The gauges are from Classic Instruments. The panel is a glove box door that I cut the back out of, drilled some holes and mounted the gauges in. I welded two 1/4" bolts on the back side of the mount panel that lined up with the stock head light switch and wiper switch holes in the dash. Made for a pretty clean installation. You could use the light and wiper switches in the stock locations to hold it in place if you wanted. I used toggle switches in lieu of the stock head light switch and also wired in a rheostat to control the gauge light brightness. I sourced the indicator lights for turn signals and hi-beams from Delcity (delcity.net). I'm real happy with it, when my Jimmy is done I'll probably have had the panel painted to match the dash or chrome plated.
I did zero modifications to the stock dash. When I had this in my 71 half ton, I used the original wiring harness with spade connectors or wire taps where appropriate. Now that I'm in the process of getting my half ton ready to sell, I don't have to clean up any hacked wiring. I re-did all the wiring in my Jimmy with a late style universal system so I wired the dash directly to the new harness. |
#4 | |
![]() Join Date: Feb 2010
Re: Gauges!!!!
Dale
1969 GMC SWB FLEETSIDE ZZ 383 CRATE MOTOR,700R4,& 3.73 POSI & VINTAGE AIR DALE JONES MY BUILD THREAD: "69 GMC SHORT FLEET" http://67-72chevytrucks.com/vboard/s...d.php?t=388447 |
#5 | |
Re: Gauges!!!!
Trz1000, I love the creativity, very nice guage panel. Dale
![]() Join Date: Aug 2001
Re: Gauges!!!!
HERES ONE I BUILT FOR MY 72 http://67-72chevytrucks.com/vboard/a...1&d=1073866525 ONGOING MONEY PIT.
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
