06-20-2010, 06:27 PM | #1 |
77 or 78 tach?
I purchased a tach cluster several months ago and finally put it in this weekend. I had to do a search to clarify a few things on the tach, I read somewhere that the clusters for 76 and 77 were the same. Looking at the pictures it looked like the cluster I installed was from a 78?? It was pretty much a plug and go set up (except for wiring the tach). Everything works except for the high beams and the temp gauge, the other temp gauge didn't work either (project for another day).
Looking at the picture can you tell what year of tach this is? Disregard the makeshift bezel, the original was in bad shape so I found one off a 79 and painted it to get me by until interior restoration. Thx! |
06-20-2010, 07:48 PM | #2 |
Future TOTM Winner
Re: 77 or 78 tach?
I'm to lazy to look up the answer, but I'm pretty sure you can find it here...
http://www.73-87.com/7387garage/inte...achometers.htm
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
06-20-2010, 08:18 PM | #3 |
What do we get for $10?
Re: 77 or 78 tach?
I believe the tach itself was the same from '77 to '79. It had the double warning lights at the bottom of the face (seat belt warning light/brake warning light). The '76 had a single warning light at the bottom.
The other differences in the cluster as a whole was that up through '77 they had a mechanical oil pressure gauge while the '78/'79 was electric. P.S. - I kinda like your bezel.
1977 GMC K25 400/400/205 1989 Chevy Suburban R1500 350/700R4 (work beater) 1994 Chevy K3500 dually 454/4L80 1996 Corvette LT4 350/ZF 6 speed 2000 Bonneville SSEI Supercharged 3.8 Liter V6 1966 Chevelle 2 door sedan (Needs major repair ) Last edited by 77gmcjoe; 06-20-2010 at 08:23 PM. |
06-20-2010, 08:46 PM | #4 |
Re: 77 or 78 tach?
Thanks guys for the feedback. I guess it was the 73-87 website that I saw that made me question the year (that is a great web-site for info!). My instrument cluster has the manuel oil pressue guage as well as the yellow and red marking on the tach that was on the 78. Not a big deal either way, just curios. I"m glad it works!
06-21-2010, 06:23 PM | #5 |
Re: 77 or 78 tach?
It is not from a '77. At least not a early '77 build.
-Don- '66 C10 w/factory A/C '77 Cheyenne K5 350/465/205 '80 Custom Deluxe K20 350/465/205 '04 Denali XL '05 DMax CCLB 4x Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf |
06-21-2010, 10:10 PM | #6 |
Future TOTM Winner
Re: 77 or 78 tach?
I agree, those multicolored warning areas starting at 4250 rpm would have been 78 or 79 only if I'm not mistaken.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com Last edited by Critter; 06-21-2010 at 10:11 PM. |
