Old 06-20-2010, 10:18 PM   #1
ehuth1
Gas leak from the drivers side fender???
Went out filled the truck up (aux tank in the bed) then went for a short cruise. I pull into the driveway, then backed up to re-adjust to the garage entrance and noticed a (splat, splat, splat, bluuuuuuuuuuuuuush) puddle marking in the driveway...? Before I can get out it's evaporated... So I proceed to leave it outside to do it's thing and pop the hood to find out it's coming from a small black canister on the drivers side that has a fuel line ran to it... Looks like it has a line going back to the fuel pump, but everyone I ask don't have a clue as to what it is. It's stopped leaking for now, but if it continues the wifes going to kick her (the truck) outside!!!!!
Someone please educate me on this mishap? I'm a newb, but I've already used the search button.
Thanks in advance.
ehuth1 is offline   Reply With Quote
Old 06-20-2010, 10:24 PM   #2
Hubscrub
Cruzin
Hubscrub's Avatar
Re: Gas leak from the drivers side fender???
that is the charcoal canister it traps or absorbs so to say the fuel vapors, but i have never seen one leak?
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8
Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U
Proverbs 3:5,6
"Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt
In memory of our first baby daughter, daddy and mommy love you.
Danica Grace 6/26/14
Hubscrub is offline   Reply With Quote
Old 06-20-2010, 10:26 PM   #3
ehuth1
This thing probably burped a 1/2 gallon??? Truck still runs fine and starts right up... Would no expansion in the gas tank from me filling it up cause the fuel to expand to here?
Old 06-20-2010, 10:33 PM   #4
El Jay
Gone to greener pastures
Sounds like the evaporation canister. If memory serves, it has a charcoal filter in it for absorbing fuel vapors.
I'm kind of wondering if your auxiliary fuel tank has a return line that's not returning to the aux. tank and thereby going to & overflowing your main tank back to the canister.
This happened to me one time when the switching valve for the return line broke & wouldn't let the excess fuel return to the aux. tank.
I hope it's something that simple for you.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 06-20-2010, 10:39 PM   #5
ehuth1
See this is a one time event, and me like a TARD filled the aux. tank up to the brim with it 100+ degrees outside. So with no room for expansion would you think there was no room for the return fuel to come back in the tank?
Old 06-20-2010, 11:21 PM   #6
trusty72
trusty72's Avatar
thats prob it. man filled up both tanks you must be rich.
1972 super cheyenne
1970 Suburb
trusty72 is offline   Reply With Quote
Old 06-21-2010, 12:25 AM   #7
El Jay
When you're drawing off the main tank, you should be returning to the main tank.
When you're drawing off the aux. tank, you should be returning to the aux tank.
So, you shouldn't have any problem with expansion when filling the tanks in 100 degree weather if everything is working correctly.
My '76 Jimmy had 3 tanks (2 aftermarket, saddle tanks) and 2 ea. 3 way valves, when I switched the valve for the fuel to the fuel pump I also had to switch the return valve.
Now, my '72 GMC has 2 tanks (factory installed aux. tank), but only 1 ea. switching valve, but that valve is like a double valve that switches both the feed & return.
I hope that made at least a little bit of sense to you.
Old 06-21-2010, 05:24 AM   #8
ehuth1
I think I've confused you guys somewhere, I have one tank in the bed. I just may have called it auxillary due to my understanding.
Old 06-21-2010, 06:15 AM   #9
dwaite72lnghrn
I would think "over filling" could cause the vent to get liquid gas in it and be pulled by the vacuum into the canister.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 06-22-2010, 09:38 PM   #10
ehuth1
Gas is back @ 3/4 of a tank and haven't had the problem since! Thanks for the info guys.
