Old 06-21-2010, 12:36 AM   #1
my51chevyrocks
my51chevyrocks's Avatar
Tailgate Hinges
I have a problem where the previous owner broke the head of the bolt that is used to attach one of my tailgate hinges. I finally got the bolt out, but in the process I ended up pushing the whole nut or housing all the way through the back of the bed frame. Now I have a hole that's bigger than my replacement bolt and I can't get to the back of the hole to put another nut and washer in. Has anyone had this problem and how did you go about fixing it?
my51chevyrocks is offline   Reply With Quote
Old 06-21-2010, 07:19 AM   #2
63 & 64 Bowties
and a few others
Re: Tailgate Hinges
I just had a similar problem with the 70 Mach-1 that my brother and I are restoring. We had a door hinge bolt break off in the captured nut. We ended up welding a nut to a washer, then cut the hole out the same size as the washer, then welded the washer to the hole with the nut facing in. (Hope that makes sense)
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 06-21-2010, 05:12 PM   #3
glowins10
Re: Tailgate Hinges
I just drilled through the other side of the stake pocket and used a longer bolt. Doesnt look bad at all!
glowins10 is offline   Reply With Quote
Old 06-21-2010, 06:49 PM   #4
my51chevyrocks
Re: Tailgate Hinges
I just might have to do that. Thanks glowins10.
Old 06-22-2010, 02:45 AM   #5
my51chevyrocks
Re: Tailgate Hinges
Had a good argument about this with my Dad. He thinks the best way to fix my broken bolt/nut issue would be to have someone weld the hole shut and then recreate threads for the original bolt. Only problem is, I don't see it being very strong without a washer and nut on the other end of it. I like the welding of a washer and nut together but how the heck am I gonna weld it on the inside of the bed frame without tearing it up. Thoughts?
Old 06-22-2010, 05:56 AM   #6
63 & 64 Bowties
and a few others
Re: Tailgate Hinges
You should be able to make the hole oval shaped so that the washer needs to be turned sideways to go in. Insert a bolt into the welded washer/nut combo to hold it into place while it's welded.
Old 06-23-2010, 06:52 PM   #7
my51chevyrocks
Re: Tailgate Hinges
Thanks Bill. I will do that.
