yes, i do
question on core support
ok so the core support on my 72 is kinda rotted out from the battery tray and washington weather. so i have a core support from the abortion of a truck that i called the 80 and was wondering if that would be a direct bolt in or would there be some modification that i would have to do to get it to fit? the current core support is going to be coming out for the tpi conversion anyway, and if i can use the square body core support i may as well use it since it's in better shape
ERROR 404....... SNAPPY COMEBACK NOT FOUND ![]() _______________________________________________________________________________________________ -60 Chevy C10, dead 350/good th350 combo, sitting on a 76 c10 blazer frame, built from 11 different vehicles "the abomination" -07 gmt900 silverado 1500 lt xcab z71, granite blue -81 suzuki gs650g "shelah"- current project -81 kz1000m1 csr "sarge" -next project (just beautification) -07 kawasaki vulcan classic vn900 |
#2 | ||
"I ain't nobody, dork."
Re: question on core support
Two completely different animals...
On the left... 69-72 Chevy, on the right 73-80 Chevy. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
yes, i do
damn..... well thanks gas.
its all about the +6 inches
its a safe bet that nothing on a square body will fit our trucks... body wise.
You can MAKE some of the stuff fit, but it's kinda like a square peg in a round hole kinda thing. |
you might b able to salvage your old original one by using the later one to cut patch panels from and make the original a sturdy more usable piece than it is now
#6 | ||
That's kinda what I did on my 1972 GMC. Pulled the core support out and cut all the rot out, fabbed up new metal, and welded it back together. Then bought an aftermarket inner fender, cuz the old one was just as rotten as the core support.
To mount the front of the inner fender to the core support. I drilled 3/8" holes through the lip of the fabbed up part to match the holes in the inner fender. Then welded nuts on the core support for new bolts with washers to go through the bottom. Gary
