Old 06-21-2010, 02:00 AM   #1
cbrwags
cummins diesel into a 65 chevy
Well I am trying to get all the bases covered on this swap so I can start. I want the truck to look stock and be able to stop/tow/drive great... I plan on boxing the frame all the way back and weld in x braces I am going to try to get a whole 2wd dodge pickup with a 12 valve or 24 valve in it, so I can use the rearend I dont know if I should 4 link or leaf? Leafs would be easyer I think. I will use the dodge fuel tank mounted under the bed. The suspension is going to be tricky to do for cheap, can I use 3/4 ton chevy arms and spindles along with the steering? will the a-arms bolt up to the 65 chevy c10?.I might try to use the dodge bakes I will need to look at what I get. I plan on using this as a daily driver and tow rig and depending how it goes, the strip. I think this will be a nice driver. I think I can get a motor, trans,rearend, for about $1500 I have done a few swaps before. What else do you think should be done to make this safe? I am looking for idea's and am not rich, and in no hurry. I am just looking for the swap truck, so in the down time looking for info.
cbrwags is offline   Reply With Quote
Old 06-21-2010, 03:53 AM   #2
raycow
Re: cummins diesel into a 65 chevy
OK, I'm a little slow here. Is the Dodge rear end 8 lug, and is that why you want 3/4 ton brakes on the front? Do you need/want to use the Dodge rear because of the gearing? If yes, it might be easier to go with a later GM rear. What ratio do you need?
Ray
raycow is offline   Reply With Quote
Old 06-21-2010, 04:12 AM   #3
cbrwags
I just want the bigger newer brake setup, that's why I was going to use the dodge rearend. When I get the whole doner truck I will check. I think 4.11s would be good. And the dodge is 8 lug also.
Old 06-21-2010, 02:09 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Honestly in a situation like that, I would think you are better off getting the whole dodge (frame, motor, rear end etc all as one) and grafting the chevy body on to it.
Keep the engine, brakes, drivetrain etc, but channel the body onto that frame. You would probably have to shorten the frame, and do custom mounts; but i still think it would be less of a hassle then converting the other way around.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-22-2010, 12:14 AM   #5
cbrwags
Yeah that sound about right. I understand that the body swap is an option and I might have to do that, I hope I can get it one way or another.
Old 06-22-2010, 12:18 AM   #6
Captainfab
60-66 Nut
I would suggest upgrading the running gear on the '65 frame to the '73-'87 C20 or C30 components. Then drop your Cummins and trans into the '65 frame and build motor and trans mounts. IMO it is easier to accomplish this, this way as opposed to body mods and mounts. BTDT
Also if you were to swap frames, that might create issues as far as title and licensing in your city, county, state. Something to consider.
Old 06-22-2010, 02:55 AM   #7
cbrwags
That is what I am shooting for I want to use the c10 frame. Do you know if the c20 or c30 a-arms will bolt up?. Thanks for the info.
Old 06-22-2010, 07:39 AM   #8
63 & 64 Bowties
and a few others
Is your C-10 a longbed? IMO shortbeds are not real safe for towing heavy trailers. And, I'm assuming you're lookin' to tow some weight with the Cummins.
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 06-22-2010, 07:52 AM   #9
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: cummins diesel into a 65 chevy
2009 Goodguys Nashville Nationals - Hot Times In Music City
1962 Chevy Pickup Truck (( Cummins Diesel powerplant. ))
This '62 Chevy has the right look with its satin black paint scheme with yellow accents, and it's definitely unique,
thanks to a (( Cummins Diesel powerplant. ))
http://www.classictrucks.com/events/.../photo_05.html
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 06-22-2010, 07:54 AM   #10
scotts62
One day...
scotts62's Avatar
Yeah that is unique, looks cool though
Scott
93 crew cab build
Project 62
Old 06-22-2010, 08:21 AM   #11
1Bad62Pro/Street
I wonder what the whole Drivetrain is on that '62?
Puff'ian out black smoke when he mashes on it!!!
Old 06-22-2010, 09:37 AM   #12
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
looks like a cummins 4bt to me. Not nearly as powerful as the 5.9 cummins you see in the dodge trucks, but def. enough grunt to get it around.
Old 06-22-2010, 10:36 AM   #13
cbrwags
Yeah that is a 4bt. Thanks for posting that, mine is a longbed. I found a 6bt gunna go take a look.
Old 06-23-2010, 01:55 AM   #14
Captainfab
60-66 Nut
Yes the '73-'87 (thru '91 on the Suburbans and CC's) control arms will bolt up to your '65 front crossmember. You will want to upgrade to the larger LCA shaft u-bolts used on the '73 and up.
Very nice looking truck there......
Old 06-23-2010, 02:52 AM   #15
cbrwags
Thanks, thats just what I needed to hear. It will be a whole lot nicer with a diesel motor in it.
Old 06-23-2010, 08:39 AM   #16
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'd LOVE to do a 6bt into a crewcab-stepside 4x4. Thats a total dream truck for me.
Old 06-23-2010, 11:23 AM   #17
cbrwags
It will be one of a kind, for sure.
Old 06-23-2010, 11:38 AM   #18
1Bad62Pro/Street
Arrow Re: cummins diesel into a 65 chevy
http://67-72chevytrucks.com/vboard/s...d.php?t=273362
Old 06-23-2010, 11:59 PM   #19
srr
This is a friend of mines 79 Chevy with a Cummins diesel in it.
srr is offline   Reply With Quote
Old 06-26-2010, 12:01 AM   #20
tapeworm
fan of "Butters" Stotch
tapeworm's Avatar
Check this site out
http://www.4btswaps.com/forum/index.php
These are kind of like the diesel version of a SBC
-people put them in everything!
64 shortbox fleetside
replacing rusty junk with more junk, and one day to become a real truck again
tapeworm is offline   Reply With Quote
Old 06-28-2010, 11:47 AM   #21
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
x2, ive seen some of the stuff on that site.....rediculous. that little motor is a cool alternative to replace an older drivetrain. Like I said, its not exactly a hot rod but will get out of its own way if a few $$ are into it.
