![]() Join Date: Apr 2004
panhard / tracking arm
Has anyone replaced the bushings in their panhard bar? I don't have a press and I don't want to screw up the new bushing. I just need to know if its easy to do or should I just spend and extra few dollars and buy a new bar and bushings pre-assembled?
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
Re: panhard / tracking arm
I haven't done it, but try a C-clamp since you don't have a press.
cclamp will do it// a bit easier if you put bushings in the freezer far a day and cleanup the hole nice and slick and use water for lubrication// i've also used long bolts wahers and nuts to pull them in
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 06-21-2010 at 10:31 AM. |
Grandpa in the rustmobile...
i think its doable with out a press
i used a press though ![]()
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Six in a row makes it go...
![]() Join Date: Mar 2009
I did it in a big bench vise. Know somebody whose got one?
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
