Compression Test Results..
Alright, with the engine @ operating temperature all plugs removed, I tested the compression. This is kind of in conjunction with this thread -->http://67-72chevytrucks.com/vboard/s...d.php?t=407911
First of all, does anyone know the correct compression for an inline 6? My results were: 1st---90PSI 2nd--90PSI 3rd--91PSI 4th--91PSI 5th--91PSI 6th--89-90ishPSI Hopefully you guys will be able to tell me something.
---| 1967 GMC Stepside |-- 250 L6 .030 over ---| 1985 Porsche 944/1 |--- Build Thread: '67 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=378640 |
Re: Compression Test Results..
Does anyone know the correct compression numbers? Im hoping I don't have to do a rebuild
#3 | ||
"I ain't nobody, dork."
That is very low for all cylinders. Was the gauge seated well enough in the plug hole? How many "pulses" did you let the gauge take to get that reading?
Good compression should be around 140 to 150. Decent will be around 120... Gary Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
Screwed all the way in, with about 5 bumps. I had the ingition coil wire grounded as well. Any idea what the problem could be??
---| 1967 GMC Stepside |-- 250 L6 .030 over ---| 1985 Porsche 944/1 |--- Build Thread: '67 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=378640 Last edited by LandonL; 06-21-2010 at 05:21 PM. |
#5 | |
Did you hold the throttle wide open?
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
Pedal to the floor the whole time.
Okay, my helper just told me not pedal to the floor, she had it about halfway..Could that have caused it?
(Never using my mom as a helper again lol)
---| 1967 GMC Stepside |-- 250 L6 .030 over ---| 1985 Porsche 944/1 |--- Build Thread: '67 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=378640 Last edited by LandonL; 06-21-2010 at 05:36 PM. |
Sheetmetal Psycho
I've never used the throttle when doing a compression test.
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up! Project "Rigginstine's Monster" 1971 C-10 longbed 355/4spd Future mods: 67 front clip Webby's Rigginations - where everything has potential! |
Alright pedal to the floor didn't make a difference, I shot a little oil in the the plug hole to see if the rings were worn, it didn't increase. So it must be leaking somewhere correct?
#10 | |
![]() Join Date: Aug 2001
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. ![]() LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
Just wish I knew what the problem was.
that is low but since they all are close its either the gauge or maybe its just a characteristic of those straight 6 engines. what problems are u having?
1972 super cheyenne 1970 Suburb |
#13 |
i see i read the other thread. atf or marvel down the carb while running, a good tune up, new elctronics in the dist. and drive it is what i would do. and prob clean the carb, recent rebuild doesnt mean a lot.
#14 |
I was going to try the ATF. By good tune up what all do you think should be done? I was planning on doing the IGNITOR II, and I was gonna do another rebuild on the carb. The gauge was a loaner tools from a brand new Oreilly's, the gauge was never checked out before me.
#15 | ||
43 years old... unrebuilt engine... is just plain ol' tired. Prolly needs a re-ring at the least. Or a full on rebuild.
How many miles on this engine? 200,000? Gary
#16 |
Only 82k, was my g. grandpa's.
#17 |
u never really know what was done to it in the past. a good tune up would be plugs, wires, cap, rotor, check out carb, and the ignitor 2 is a great idea. these are things your gonna buy if you rebuild or not, so what do you have to lose?
#18 |
Some fresh rotella 10w-30 and beating the tar out of it for an extended length of time might help. 80000 miles isn't extremely high. But it might need a rebuild
'72 cheyenne super step, '05 long bed gmc |
#19 | |
![]() Plugs & Wires have been recently done, but I think I might upgrade a MSD kit. Im thinking on one of the offenhauser intakes, what carb would be best 4bbl or 2bbl and how many CFM?
