Old 06-21-2010, 06:03 PM   #1
quentin hill
quentin hill's Avatar
Need a solution
Well I got my wheels in today but I have a problem. I have a 72 chevy stepside and I ordered 15x10 ralley wheels for it but they stick out 2" past the fender. LOL So I need some help should I have the (original) rearend shortened 2" on each side? should I purchase a used rearend and have it shortened? I do not want to go with a small size wheel.
Any help would be much appreciated.
"TO GO AN EXTRA MILE AND PERFORM MORE THAN WHAT ONE IS COMPENSATED FOR"
quentin hill is offline   Reply With Quote
Old 06-21-2010, 06:06 PM   #2
gregg72340
gregg72340's Avatar
Re: Need a solution
Is there enough clearance to make up the difference in the backspacing of the wheel?
Just would like the snow to stop so I can actually work on my truck!!!!!!!!!!!
gregg72340 is offline   Reply With Quote
Old 06-21-2010, 06:19 PM   #3
quentin hill
Re: Need a solution
I am not sure what you are asking. But I think you are asking if I changed the wheel to a 6.5" backspace instead of a 4.5" would it fit?
The backs yes the fronts no.
Old 06-21-2010, 06:21 PM   #4
quentin hill
Re: Need a solution
If I changed the drums to disks would this narrow the rearend?
Old 06-21-2010, 07:19 PM   #5
gregg72340
gregg72340's Avatar
Re: Need a solution
Yep that was what I was asking LOL, switching the backspacing on the backs is an easier solution than narrowing the rear and I think you might gain something by going to front disk but dont think it would be the amount you need
Old 06-21-2010, 07:20 PM   #6
gregg72340
gregg72340's Avatar
Re: Need a solution
Sorry just though of this is it a 1/2 ton, then shouldnt it already have front discs anyway????
Old 06-21-2010, 07:26 PM   #7
cdowns
cdowns's Avatar
Re: Need a solution
a 72 has disc fronts already// a 6.5 backspace in front will probally cause problems with cleanance issues when turning a 6.5 backspace in rear might need to reroute thhe emergancy brake cables a bit or tire might hit the bedside too
Old 06-21-2010, 07:28 PM   #8
quentin hill
Re: Need a solution
It does on the front and the rims fit fine there. The rear is where the problem is and that is where I was thinking of changing to discs but I am not sure of the cost. What is cheaper a narrow rearend or discs and with the discs do you really gain anything.
Thanks for your help
Old 06-21-2010, 08:13 PM   #9
cdowns
cdowns's Avatar
Re: Need a solution
the axels and studs are in the same place with rear disc it changes nothing as far as track width
Old 06-21-2010, 08:17 PM   #10
truckdude239
truckdude239's Avatar
Re: Need a solution
71-72 come factory with disc
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 06-21-2010, 08:18 PM   #11
quentin hill
Re: Need a solution
Really, on the rear?
Old 06-21-2010, 08:50 PM   #12
71tahoe
71tahoe's Avatar
Re: Need a solution
It might be cheaper to widen the fenders than narrow the rear.
71tahoe is offline   Reply With Quote
Old 06-21-2010, 09:15 PM   #13
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Need a solution
No... The rear are drums... front are disc. But to narrow the rear end is a lot of work and cash, when you can just get the proper backspacing for the 2 rims in the rear.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-22-2010, 03:32 PM   #14
quentin hill
Re: Need a solution
Quote: No... The rear are drums... front are disc. But to narrow the rear end is a lot of work and cash, when you can just get the proper backspacing for the 2 rims in the rear.
That is the problem these rims only come with a 4.5 to 5" backspace. I have the 4.5" now but I need to gain 2 more inches, .5" is not going to be enough (That's what she said ) I have been doing some research and it seems that to narrow a GM rearend would cost a lot of money.
I really want these wheels on my truck but maybe common sense says to just go with the 15x8's. DADGUM
Old 06-22-2010, 03:59 PM   #15
Dingfodgy
Lemme show you something!!
Dingfodgy's Avatar
Re: Need a solution
I would check with Stockton Wheel Service- they will either modify your existing rims to whatever BS you want or make you a new set- again to whatever backspace you desire. You shouldn't need to narrow your rearend to run 10" rims.....folks do this all day long. You just need to get your backspacing dialed in and you'll be good to go.
'67 CST-10 LWB ("Crusty") SOLD
'67 GMC SWB ("Murdock")
2000 K1500 Suburban ("Betty")
'95 BMW 325i ("Joy")
Dingfodgy is offline   Reply With Quote
Old 06-22-2010, 05:27 PM   #16
quentin hill
Re: Need a solution
That my friend is the best news I have heard all day.
Thank you so much
Old 06-22-2010, 06:47 PM   #17
cdowns
cdowns's Avatar
Re: Need a solution
have you mounted tires on these rims yet to measure the actual clearance in the rear to the bed sides? i'd hate to hear you spent a bunch changing the rims than with tires mounted they hit the bed
