Old 02-16-2003, 06:27 PM   #1
PloreOSU
Sway bar swap
Does anyone know if the front and/or rear sway bars from a 03 Tahoe will fit under a 72 Truck? Also, if someone has the dimensions from our bars, that would be great as well. Thanks.
72 GMC, 2x4, LWB Fleet
DONE: 2/3 drop, 17" rims, front end rebuild, front/rear sway bars
Working on: old air AC, blazer tank, rear discs, 03 silverado seats.
PloreOSU is offline   Reply With Quote
Old 02-18-2003, 01:48 PM   #2
PloreOSU
bueler....bueler... (ttt)
Old 02-18-2003, 04:23 PM   #3
72CustomCamper
OK, OK...i'll play.
I really doubt it.
'72 GMC C20, "2500 Super Custom", Custom Camper, New 454
'93 K2500 Suburban, Old 454 (157K)
72CustomCamper is offline   Reply With Quote
Old 02-18-2003, 04:26 PM   #4
progress
Gotta luv a clean shave
If you can find a way to bolt of weld them to the frame they will fit...LOL! Not sure about the Tahoe but so many of the later models do fit. Just measure distance between the frame rails. Those mounts usually are adjustable anyway. In my truck they are welded on. I am switching them to another truck so I will just bolt them in. The end that attaches to the lower A-arm just bolts through an eye in the stabilizer. Just use a tape measure on that end to see where it would have to mount on the "67-'72 A-arm. If it is close...no problem.
Welding while you wait...you can help if you like and it...might even save you a little as long as you don't mess things up!
We make house calls too...just like the old days!
progress is offline   Reply With Quote
