06-22-2010, 12:51 AM | #1 |
newbie question on bed wood replacement
I bought Mar-K's pine wood replacement kit, alsong with the intructions and new bed wood rails and bolts and bed mounting pads. Is it absolutely necessary to remove the bed from the frame to do all this? 66 SWB fleetside...What way is recommended?
06-22-2010, 04:00 AM | #2 |
1961 crewcab
Re: newbie question on bed wood replacement
might be a pita to get at some of the bolts that are over/around the frame rails..
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
06-22-2010, 07:17 AM | #3 |
Plan on removing the bed and getting it set up on saw horses or some other sturdy work surface where you have access all around it. You will be glade you did.
You will be removing all the fasteners that hold the bed to the truck. At that point all you need to do is unhook the wiring harness and the bed will come right off with a little help from 3 of your best friends or, if you are a loner, an engine hoist. Access to all the fasteners will be "nightmarish" trying to install the wood with the bed still on the truck. Also if your truck is like mine was you will have to cut or twist-off many of the old original carriage bolts and fasteners becasue they are rusted beyond the point of disassembly. Hope this helps. Last edited by lakeroadster; 06-22-2010 at 07:18 AM. |
06-22-2010, 06:35 PM | #4 |
you could bo what i did and have your wife or girlfriend get under it nd tighten them down
im with these guys
66 chevy lwb 355/400 |
06-22-2010, 11:33 PM | #5 |
Thanks all- will post pics later!
06-23-2010, 11:05 AM | #6 |
I did mine without removing the bed. I had a helper in the bed holding the old bolt heads with vise-grips will I was under the bed zipping the nuts off with an air ratchet. Installing the new wood & strips was a breeze. Photo...
06-24-2010, 01:28 AM | #7 |
is that black paint or black stain? beautiful job!!
06-24-2010, 02:45 PM | #8 |
Thanks! One coat of Sherwin Williams oil based primer, and two coats of Sherwin Williams black semi-gloss oil-based exterior house paint.
06-25-2010, 02:47 AM | #9 |
Lakeroadster is right about them either coming off or breaking off. I used a die grinder and cut a slot in the head of the carriage bolts and held it with a large screwdriver while my friend was under the bed with a rattle-gun. About 1/2 broke off and I used some Kroil on them several times. It's a ***** and at best a little hard work....Vernski
06-25-2010, 03:40 PM | #10 |
When I removed mine, most were rusted bad. Since I was replacing the rusty rails, I grinded the heads off. Fell right off through the bottom.
1961 GMC Suburban Custom 1969 Short wide project http://67-72chevytrucks.com/vboard/s...d.php?t=535479 (SOLD) 1959 Apache fleetside (frame off in progress) http://67-72chevytrucks.com/vboard/s...d.php?t=348746 1960 Apache short/narrow shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=350780 (SOLD) 1951 Plymouth leadsled project 2005 Corvette conv. Procharged 1969 Corvette stingray 2006 Cadillac XLR-V 1950 Oldsmobile 98 custom project |
06-25-2010, 04:15 PM | #11 |
The first board is the hardest the rest of them you can reach around to the bottom through the hole created by removing board. You also will want to soak them in liquid wrench.
08-01-2010, 09:07 PM | #12 |
Well I got r done! Here's pics!
08-01-2010, 09:21 PM | #13 |
good job!! i need to do mine!!!!
08-01-2010, 09:33 PM | #14 |
It's pretty easy to remove the bed. I'd recommend it, although it can absolutely be done on the truck with some effort.
If you're not reusing the bed strips, I find it easier to set up a small impact with a square drive, go on the bottom, and set it to tighten rather than loosen. It immediately breaks every one of them. It's a lot easier than trying to back off the nuts. Sometimes the bed strips don't get wrecked using that method - it depends on how easily the bolts break. |
08-02-2010, 02:37 PM | #15 |
Lookin' good!
08-03-2010, 12:38 AM | #16 |
Oh, by the way I painted it with POR-15 paint...
08-03-2010, 01:11 AM | #17 |
looks good. gotta find time to do ours one day
01-27-2011, 12:45 PM | #18 |
how much por 15 did you use , I plan on doing the same thin but I need to know how much I need to buy?
1970 Custom camper 20 lwb 1978 yamaha xs1100 (insert clever quote here) |
01-27-2011, 01:20 PM | #19 |
To my knowledge, POR-15 doesn't stand up to UV rays without turning milky.
01-27-2011, 11:29 PM | #20 |
01-27-2011, 11:49 PM | #21 |
01-27-2011, 11:52 PM | #22 | |
01-29-2011, 05:20 AM | #23 |
The bed looks good. If anyone is interested i found this site that gives you the measurements to cut the wood yourself. I plan on trying this one day. The kits are just to expensive for me.
http://www.classicheartbeat.com/bed_wood.htm |
01-31-2011, 02:52 PM | #24 | |
