Old 02-16-2003, 07:22 PM   #1
Boardrider52
Boardrider52's Avatar
X-pipe/H-pipe
i was wondering what is better for performance and sound an X-pipe or an H-pipe.
72' Jimmy
member of Above~n~beyond truck club
members.fortunecity.com/aboveandbeyondtrucks
Boardrider52 is offline   Reply With Quote
Old 02-16-2003, 08:45 PM   #2
crazy longhorn
Fabricate till you "puke"
The X pipe will no doubt give better performance, but they are a little harder to fit to most chassis. The h pipe is older tec, but does work...........crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 02-16-2003, 08:58 PM   #3
71Seth
71Seth's Avatar
boardrider52
i had the same ? on my mind mhen i came here but i see you beet me to it. Is it a worth the $ for the x pipe? Anyone running x's on their trucks?
97 ext cab 4x4
04 pontiac grand am
05 honda rancher AT (yellow)
71' C-10 swb sb400 th350 .040, 292 Mag comp cam, high rise Edelbrock w/750 duel feed Holley, Accel super coil and wires, B&M ratchet shifter
71Seth is offline   Reply With Quote
Old 02-17-2003, 01:12 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Either way you go...if you have the $$ have the pipe benders put some sort of bolt on parts so you can unbolt the X or H section so you can drop your tranny....some set ups make it near impossable to remove the tranny pan. Had a truck come into teh shop the other day just like that. Took almost an hr just to remove the tranny pan. And you shoulda smelled the burned dextron on the pipes whn we fired it up afterwards! YUK!
Old 02-17-2003, 03:08 AM   #5
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Our system does not get in the way of the transmission pan nor the removal of the transmission. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 02-17-2003, 07:15 PM   #6
71Seth
71Seth's Avatar
wes, that looks like some fairly sharp bends in the pipes. Is that just the angle of the pic?? Hedmen gets $168 for their 2.5 pipe whats your worth? X pipe only.
seth
97 ext cab 4x4
04 pontiac grand am
Old 02-17-2003, 07:55 PM   #7
Smitty
Smitty's Avatar
I had mine installed like Wes's. The pipes Siamesed but had flanges put on forward and where they go back under the bed so that if I ever have to pull the trans all I have to do is remove this section of the exhaust to make it that much easier on myself.
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
