Old 06-22-2010, 05:03 AM   #1
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Exclamation 1970 Chevy 400 cu in SB, Casting 3951511 Canadian Block
Casting 3951511
Canadian Block
4 Bolt main
.30 over
Hypertec Pistons
Piston to Wall Bottom .025
Top .030
Good Hone
No Ring Land
No heads
New Cam and Lifters and Double Roller Timing Set
Cam = Doug Herbert 285-295
Duration = 465 Int. 495 Exh. lift
$750.00
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 07-02-2010, 09:47 AM   #2
The_BullDog
The_BullDog's Avatar
Re: 1970 Chevy 400 cu in SB, Casting 3951511 Canadian Block
pm sent.
The_BullDog is offline   Reply With Quote
Old 07-02-2010, 12:18 PM   #3
1Bad62Pro/Street
Thumbs up Re: 1970 Chevy 400 cu in SB, Casting 3951511 Canadian Block
Replied to your PM Bud.
Will be around the phone.
Old 07-03-2010, 12:17 AM   #4
Captainfab
60-66 Nut
You really ought to be putting this into your '62......JMHO
Old 07-03-2010, 09:12 AM   #5
1Bad62Pro/Street
Ha ha...
Well for right now Bud it looks like I will use the 355 for now.
It needs serious attention to appearance. Looks a mess.
Still need valve covers and breather.
I really want the double barrel shot gun scoop.
But they are super expensive.
Now I might get a crate motor later.....
Later means.....way later.
Maybe one day I will run up on a early 427 in good shape real cheap!
But the odds in that is very slim.
Old 07-19-2010, 06:04 AM   #6
1Bad62Pro/Street
Exclamation Re: 1970 Chevy 400 cu in SB, Casting 3951511 Canadian Block
UPDATE
No Cam...........
No Lifters.............
NoTiming Set...................
$450.00
1bad62prostreet@gmail.com
Old 07-19-2010, 10:49 AM   #7
ripdog28
ripdog28's Avatar
IMO, take your 355 rotating assy and get 406 pistions for a 377 destroker. Will eat up those 355's all day long with the same top end.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 07-19-2010, 11:14 AM   #8
1Bad62Pro/Street
For now Bud,
I will keep my 355 like it is but with few upgrades....
Old 09-15-2011, 12:00 PM   #9
1Bad62Pro/Street
Arrow Re: 1970 Chevy 400 cu in SB, Casting 3951511 Canadian Block
Update:
1970 Chevy 400 cu in SB out of a Chevy K-20
.030 over Good Hone No Land
Casting 3951511 Canadian 4 Bolt Main Block
3 Freeze Plugs
Balanced Rotating Assembly
I-Beam Rods Cleared for High Lift Cam
COR Hypertec Aluminum pistons Dish Type
.010 cast crank 3951528 - Low miles
Good Clean Polished Finish
needs Decked and some Heli-Coils Installed
$400.00 OBO
Old 09-15-2011, 08:29 PM   #10
qksilver
curious and interested. How much needs to be taken off the top? would a thick head gasket work? and what needs to be heli coiled? I am trying to put together a cheap short block, that i can build later. I have good heads and cam........but my engine has two spun main bearings. Not sure where clevland county is but I am by Fayetteville and am off Thursdays and Friday but not this friday.
Pm me sometime and we can talk
Thanks,
Steve
qksilver is offline   Reply With Quote
Old 09-15-2011, 08:45 PM   #11
1Bad62Pro/Street
Wink Re: 1970 Chevy 400 cu in SB, Casting 3951511 Canadian Block
Thanks,
Steve
PM sent Bud.
Old 09-29-2011, 10:53 PM   #12
bigboi
has the crank been turned and if so what are the specs
bigboi is offline   Reply With Quote
Old 09-29-2011, 11:13 PM   #13
1Bad62Pro/Street
PM sent Bud.
Old 09-30-2011, 07:02 AM   #14
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Hey feller, what needs to be helicoiled? I'm super interested & can make a road trip, how far are you from 37806? Has it been checked for cracks? New cam bearings? How much is the block out? Thank you
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 09-30-2011, 07:21 AM   #15
1Bad62Pro/Street
PM sent Bud.
Old 09-30-2011, 08:00 AM   #16
71 super
71 super's Avatar
I am curious about the helicoil issue as well. I am really close and can pick up this week end. Threads pulled on the block I assume? Roughly how many miles etc. Thanks H
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 09-30-2011, 12:56 PM   #17
1Bad62Pro/Street
PM sent Bud.
Old 09-30-2011, 08:23 PM   #18
1Bad62Pro/Street
Guys,
My father & I Will be at a car show tomorrow from 9am-3pm
http://67-72chevytrucks.com/vboard/s...03#post4928803
http://www.cruisincarolinamagazine.c...onth/all/all/1
The 1947 - Present Chevrolet & GMC Truck Message Board Network > Regions > United States of America > Southeast
http://67-72chevytrucks.com/vboard/f...play.php?f=117
Old 11-22-2011, 10:40 AM   #19
1Bad62Pro/Street
4.125 in bore family (1970–1980)
400
The only block of this family, 400 cu in (6.6 L) small-block, was introduced in 1970 and produced for 10 years. It was loosely based on the medium journal 350 and had a 4.125-inch (104.8 mm) bore and a 3.75-inch (95.3 mm) stroke. The 400 differed from other small blocks in that the cylinders were siamesed, used a 2.65” large journal, and oftentimes had one more freeze plug on both the left and right sides of the block. Initial output was 265 hp (198 kW) and was only available equipped with a 2-barrel carburetor. In 1974 a 4-barrel version of the 400 was introduced, while the 2-barrel version stopped production in 1975. 1976 was the last year that the 400 was used in a Chevrolet Passenger car, available in both A-Body and B-Body lines. While popular with circle-track racers and drag racers, the engine was prone to cooling problems if cylinder heads without steam holes were used.
Production: 1970–1981
Displacement: 400 cu in (6.6 L)
Power: 150 hp (112 kW)-265 hp (198 kW)
Bore and Stroke: 4.125 × 3.75 in (104.8 × 95.2 mm)
