Tracking arm
Do i need a adjustable tracking arm or can i use my stock arm, when dropping the rear 2" and front 1"?
Re: Tracking arm
Use your old one. I dropped the rear 4 inches, and used the old one.
Re: Tracking arm
My guess is you will be alright, That said, I would put a Super Track Bar Kit on the shopping list.
**Taken from ECE Website:: With a rear drop of more than 5”, the stock panhard bar actually runs at an uphill angle to attach to the rear axle. This causes the rear end to shift to the driver’s side as the rear suspension travels downward, creating an ill-handling driving situation. Last edited by Kayotic; 06-22-2010 at 09:14 AM. |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Re: Tracking arm
With 2" you should be alright to use the stock one. Between 2" to 4" I would use the adjustible one. 4" and more I would use the super bar kit. This is just a rule of thumb, and each situation will be a little different. Bottom line is the rear end needs to be centered between the frame rails for the truck to track correctly and not ware out tires prematurely. The best way to tell is to lower it and measure the rear brake back plates it the same location to the frame rail in the same location from side to side. If the measurement is off, if it were me I would center it. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
