![]() Join Date: Jul 2009
15x10 vs. 15x8
Will i gain any tire width by going from a 8in rim to a 10in rim with a 275/60r15
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
#2 | ||
"I ain't nobody, dork."
Re: 15x10 vs. 15x8
No... regardless of rim size... the tire tread width should stay the same. Unless you are going to a wider tire than before.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
Re: 15x10 vs. 15x8
Ok id like a little wider that a 60 series. can i get a 275/70r15
#4 | ||
Re: 15x10 vs. 15x8
The "60" and the "70" are not the tread width... that is the side wall height (which is a percentage of the tire width). The width is the "275". You need to go to a "295" or larger size tire.
Gary
Re: 15x10 vs. 15x8
Ok well thanks i feel like an idiot now. Thanks for the help bro
#6 | |
Re: 15x10 vs. 15x8
I'd like to find a wider and taller tire than the 275/60/15 that's on my truck. I want to stay with the same rim because I've got a nice set of cragers on it but I'd like a wider and taller tire to help when I drive my truck on the highway. Bfg used to make a 285/70/15 but as far as I can find they no longer make it. If anyone knows of a tire in this size I would love to hear about it.
Ben _____________________________________ 1971 Chevy shortbed 350/4-speed sold 2005 Chevy Duramax EC/4x4 Local 597 Pipefitters certified TIG MIG and stick welder |
laying low
![]() Join Date: Mar 2001
Re: 15x10 vs. 15x8
Putting say a 275/60 on an 8" rim will give what I believe is called a "section width" of say 10". Put the same tire on a 10" rim will give a wider section width by a couple of inches but the tread width remains the same. The wider rim just moves the sidewalls out a bit more is all giving the look of more tire.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
Re: 15x10 vs. 15x8
Coker Tires sells 285/70/15s
