Old 06-22-2010, 06:38 PM   #1
tucsonjwt
Can anybody with a manual transmission check?
Does the swivel on the clutch adjustment rod go in the lowest hole of the bell crank ("Z bar") or does it go on the second hole up, which has a raised boss and slightly smaller diameter opening.?
I am working on the clutch adjustment on my 83 C20 with SM 465 manual 4 spd. transmission. The clutch keeps going out of adjustment. There are two holes on the bottom of the bell crank (Z bar). My existing setup has the threaded "lower pushrod" swivel installed on the lowest (furthest down) hole. This results in some "slop" in the swivel which may account for the frequent loss of adjustment. The other hole (higher up) looks like a better match for the stud on the swivel, but it would put the adjustment rod at a sharper angle to the clutch fork.
Any ideas?
Thanks.
tucsonjwt is offline   Reply With Quote
Old 06-23-2010, 05:35 PM   #2
BigRed76
BigRed76's Avatar
Re: Can anybody with a manual transmission check?
on my 76 the clutch adjustment bar is on the lower hole of the z-bar.
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Old 06-23-2010, 07:23 PM   #3
tucsonjwt
Thanks BigRed. I wonder what the other hole is for? I have seen it described as a "gage" hole elsewhere.
Old 06-24-2010, 09:13 AM   #4
swb85
On a budget like Fred Sanford
swb85's Avatar
The other hole should be for a return spring, one end goes there and the other on the frame.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 06-24-2010, 10:47 AM   #5
tucsonjwt
My return spring hooks to a bracket on the clutch fork. Is that an incorrect setup?
Old 06-24-2010, 12:52 PM   #6
swb85
swb85's Avatar
It'll work, I've seen them both ways. Some have one spring going from the frame to the fork, others have a spring going from the frame to the z-bar and another from the fork to the z-bar.
Old 06-24-2010, 03:23 PM   #7
ECU PIRATE
ECU PIRATE's Avatar
Grab yourself a copy of the catalog from Classic Parts. They have a complete diagram in there with all of the parts numbered. This is the diagram I will be following when I order extra parts to complete my swap
The Fleet........
68' Camaro - 1st car (restored & still have it)
09' VW Tiguan (Wife's Daily Driver)
14' VW Passat SE TSI (my personal)
14' Ford Edge Sport (Daily Work Vehicle)
73' SWB Stepside - 77K org. miles
74' LWB 454/TH400 - drive train transplant for my (Sold)
98' SWB C1500 W/T - shop truck (Sold)
90' GMC Sierra SLE short step - aka " Jezabelle " (Sold)
ECU PIRATE is offline   Reply With Quote
Old 06-24-2010, 05:52 PM   #8
tucsonjwt
Thanks. I am looking at the Classic Parts diagram. Nothing appears to go in that second (highest up) hole in the end of the bell crank. Is that a wave washer between the cotter pin and the flat washer at the end of the bell crank at the swivel attachment? (The catalog just says #22, which is for the whole kit.) Is it: cotter pin, wave washer, flat washer, bell crank OR cotter pin flat washer, wave washer, bell crank? I have no wave washer - maybe that is my problem.
Old 06-24-2010, 06:51 PM   #9
tucsonjwt
I also see two springs in the Classic Parts diagram: clutch pedal return spring and clutch fork pullback spring. I have the clutch fork pullback spring, but I don't see where the clutch pedal return spring goes. Do you manual transmission guys have two springs? If so, where does the clutch pedal return spring connect. I can't quite make out the attachment points on the drawing. The drawing makes it look like both springs connect to the clutch fork - which can't be right. Thanks.
Old 06-24-2010, 09:30 PM   #10
BigRed76
BigRed76's Avatar
my 76 only has the clutch pedal return spring, and its up underneath the dash on the clutch pedal. i didnt know there was supposed to be a spring on the clutch fork...
Zach
Old 06-25-2010, 12:29 AM   #11
tucsonjwt
Maybe you get one or the other, not both. When I disconnected the spring to the clutch fork the clutch pedal dropped to the floor. I disconnected the spring to install a new clutch fork boot. I don't know why you would need two springs in about the same location, as appears to be the case on the Classic Parts drawing.
Old 06-25-2010, 07:49 AM   #12
ECU PIRATE
ECU PIRATE's Avatar
If you figure it out. Let me know. I know somebody on here is running a SM465 in their rig and can take some pics
The Fleet........
Old 06-25-2010, 08:42 AM   #13
68 TT
Still plays with trucks
68 TT's Avatar
Mine has both springs and the small bracket that is bolted to the clutch fork for the spring to attach to.
I can take some pics later today if needed.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 06-25-2010, 11:07 AM   #14
tucsonjwt
Yes, please take pictures and post them. I have the SM465 with the spring on clutch fork bracket to frame, but that appears to be all. Since my clutch keeps going out of adjustment, maybe another spring would help. Also, the correct arrangement of the attachment hardware for the "lower pushrod assembly" (or adjustment rod) would be nice to know: i.e. cotter pin, flat washer, wave washer, bell crank - or whatever the correct sequence is.
Perhaps Keith Seymore can post on this, since he was there in the plant when these trucks were built, and he has a 100% correct specimen to look at.
