Old 06-22-2010, 07:14 PM   #1
Davetopay
Rim stuck to hub.....
Passenger side rear rim won't break loose from the hub! Tried kicking it, 5# sledge, etc.
I was thinking of making a giant puller tool with some angle iron, a threaded bung, and a really long bolt. Aside from that, I am running out of ideas.ANy help?
....oh yeah.....80's 15x8 Blazer Rally rim on a 70 GMC with the stock 12 bolt rear.
Davetopay is offline   Reply With Quote
Old 06-22-2010, 07:18 PM   #2
Eturnit3
Bloodied Knuckles
Eturnit3's Avatar
Re: Rim stuck to hub.....
heat... thermal nuclear expansion.
Eturnit3 is offline   Reply With Quote
Old 06-22-2010, 07:37 PM   #3
OrrieG
OrrieG's Avatar
I had a rear drum rusted to the hub. I wasn't in a hurry but it took half a dozen tries over a couple of months to get it off. I could not get the puller to hold and ended up spot welding bent flat stock to the drum, torqued it like crazy and after the right mix of penetrant, wd 40, heat, ice and BFH it popped. It sat with pressure on the puller bolt for a couple of weeks. I did not apply a lot of heat, did not want to warp the axle or hub.
OrrieG is offline   Reply With Quote
Old 06-22-2010, 07:41 PM   #4
msgross
msgross's Avatar
Are the lugnuts off?
you could always pull the diff cover, take out the bolt,pin and C-clips and pull the entire axle... then you would avoid more bearing damage...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 06-23-2010, 02:38 AM   #5
milled
milled's Avatar
Dead Blow Hammer (biggest) wd 40 it daily for a week then beat the SH*& out of it. If you use a torch use the rose bud tip and turn it up real real high.
1970 k20 350 4speed hd44 14b
Circumventing the language filter is against site rules
milled is offline   Reply With Quote
Old 06-23-2010, 09:30 PM   #6
USSkoval
Not just a big dead-blow hammer, but a BIG dead-blow hammer
Something that has worked for me, is simply ramming the stuck wheel/tire with another wheel/tire of similar size.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 06-23-2010, 09:36 PM   #7
71swb4x4
71swb4x4's Avatar
I did what msgross suggests. I pulled the whole axle and then still had to work a little to get it off, but it sure made life a lot easier.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 06-23-2010, 10:01 PM   #8
409sbc pwr
409sbc pwr's Avatar
had the same problem with a 69 nova a just bought not to long ago! we tryed everything other then pulling the axel didnt want to go that far so we backed the lugs nuts off and did a a power brake burn out forward and then in reverse broke it loose! i know this is prolly the most hillbilly redneck solution out there but it worked for me lol
84 3/4ton swap 4x4, 409sbc 37x13.50 toyos 8 inch superlift
2007 2500 HD, 10-12 cognito lift, 38x13.50 toyos soon to be boosted via rearmount system
409sbc pwr is offline   Reply With Quote
Old 06-23-2010, 10:02 PM   #9
chas350
From the other side of the truck slide a 2x4, 2x6 or 4x4 under the truck and whack the back of the rim with it. Its worked well for me, given the weight of the wood and the inertia developed.
"I'll Procrastinate Tomorrow"
quote by LEEVON
71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's
70 K20 long fleet
98 G3500 work van
chas350 is offline   Reply With Quote
Old 06-23-2010, 11:00 PM   #10
7T2
Active Member
7T2's Avatar
Did you back off the brake adjuster? Sometimes that helps. Failing that, empty a couple cans of PB blaster into every crack that goes between the drum and hub.
1957 GMC Ambulance
1962 Belair Wagon
1963 C80 Truck Cab *FOR SALE*
1969 Chevy C10 Short Bed
1972 Chevy C10 Long Bed *SOLD*
1996 C3500 Dually *SOLD*
7T2 is offline   Reply With Quote
Old 06-24-2010, 06:52 AM   #11
Davetopay
I used my brain on this one.
I gave it to the shop up the street. Work hours, lack of driveway, garage, and desire make it the wise choice!
Old 06-24-2010, 09:52 AM   #12
propanemudtruck
Local Redneck Authority
propanemudtruck's Avatar
That won't help get the wheel off the hub/drum...
-Kevin
four on the floor feel the beat in your soul
movin to the rhythym pumpin til ya cant take no more
dance if you want to do what you came to
you cant ignore the feeling of that four on the floor
propanemudtruck is offline   Reply With Quote
Old 06-24-2010, 11:32 AM   #13
kwmech
loosen the lugs up about a thread or 2 shake the truck side to side or drive up and down the driveway a bit
Old 06-24-2010, 10:24 PM   #14
lurch115
lurch115's Avatar
loosening the lug nuts a turn and either wiggling the vehicle or driving it around the block has always worked for me on the most stubborn rusted one wheels/drums. just make sure to drive SLOW if you go around the block.
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 06-29-2010, 12:47 AM   #15
dammitmitchell
the pollock
dammitmitchell's Avatar
DUDe penetration oil!
PB blaster or some kroil.. spray the front and the back and wait a few hours.. that stuff eats the rust etc and will break it free
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 06-29-2010, 04:06 AM   #16
Matt Man
Matt Man's Avatar
50lb sludge and use some heat on it.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 06-29-2010, 10:43 AM   #17
msgross
msgross's Avatar
like this?
The Garage:
Old 06-30-2010, 11:56 AM   #18
aboveall
Junior Member
with all lug nuts off jack it up as high as the jack will go then turn the handle of the jack fast to let it down and it will slam down hard and fast and usally brakes the rim free from the drum the weight of the vehichle should brake it free ive done that a few times always worked
aboveall is offline   Reply With Quote
Old 06-30-2010, 09:32 PM   #19
Davetopay
Heh...all is well. I am now riding in bias ply heaven.
Old 07-01-2010, 10:08 AM   #20
Yukon Jack
Post Whore
Yukon Jack's Avatar
So what did it take to break it free??
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 07-02-2010, 05:44 AM   #21
Davetopay
Several days of PB blaster soaking, loose lugs with a drive around the block, and a lot of BFH.
